Old 01-29-2004, 08:38 AM   #16
KevanB's Avatar
https://mmm1107.verio-web.com/grayma/catalog/803.htm
Would this work for a charger? We have a couple of these lying around school, and I could maybe buy one for cheap $$.
KevanB is offline   Reply With Quote
Old 01-29-2004, 02:14 PM   #17
hawker's Avatar
kevan,
while the voltage is there (up to 15v), there is not enough amperage there, only 300ma which will not be enough to run a charger?
correct me if i'm wrong guys.
hawker is offline   Reply With Quote
Old 01-29-2004, 02:34 PM   #18
correst, 300ma is NOT enuff to run a charger.
your PS should be able to handle the same as, or more than the max amp rate your charger can put out.
MManson is offline   Reply With Quote
Old 01-29-2004, 02:42 PM   #19
KevanB's Avatar
Yeah, at least I tried.
But anyways my PC Power supply is going good, I jsut need to know if this is all I need to do:
1. Remove all unnecessary wires (that arent black, yellow, red)
2. Then just get ONE yellow, and ONE black wire. Lead them out or make a connector for them to the charger?
Please help me on this.
Old 01-29-2004, 03:27 PM   #20
IMO, the existing wires (20ga?) are a bit small for the loads you MAY be asking them to carry. I took the yellow & black & red wires, and made 4 bundles ( 2 black) for neat routing. then I took the yellow, and split them, running half (2 in my case) to one plug, and half to another. I now have 2 12V hot leads. Same with the black (2x per black bundle, 4 groups total) leaving me with 2 neg. leads for the 12V, and 2 for the 5V. The 5V wires I divided in half, running one half to a plug, the other half to a set of resistors as described at
http://www.holmes-ave.freeserve.co.uk/atx-psu-mod.htm
In reveiw, this gives me 2 12V circuits for use, 1 5V circuit for use, and 1 5V circuit w/ resistors.
In reference to "plugs", I'm using Bannana jack plugs from radio shack, on a seperate panel. Trying to cram all of this stuff into the existing box is a bit too tight for my comfort level.
further info, I've got a small peak charger (5A max) that I run with this, and nothing else. The 250W PS I used says it'll give up to 9A @ 12V, but I have no way of checking that. I just completed this thing a few days ago, and it seems to work well for my purposes, but I'd buy one of those E-bay PS's next time around.
Standard disclaimer: It can be dangerous to fool with electronics like this if you don't know what you are doing... I am not a professional; in fact I have very little electronic experience, so attempt this at your own risk!!!
Corruptor is offline   Reply With Quote
Old 01-29-2004, 07:46 PM   #21
I'm currently using a 300 watt redundant hot swap old AT server power supply to use, I gutted all the power wires, and re-ran new wire from the pc board to outside the unit to poles.
I have 12+/ground/+5 on the front, and I just clip on to what I use.
Im just using a duratrax digital intellipeak and so far it works ok...
I have a question, Why do people put the resistor across the 5+ leads? does that raise the voltage on the 12+ side?
Old 01-29-2004, 07:48 PM   #22
KevanB's Avatar
From what Ive read so far, yes, that is what the resistors are used for. I probably wont continue my power supply, something is horribly wrong with it.
Old 01-29-2004, 08:29 PM   #23
RL Junior's Avatar
Yes, computer power supplys are regulated by the 5v... so in order to get proper 12v output there needs to be a load on the 5v side. You can use a variable resistor (potentiometer) on the 5v and then simply adjust the knob until you get the voltage you need from the 12v leads (check it with a voltmeter).
RL Junior is offline   Reply With Quote
Old 01-30-2004, 02:54 PM   #24
KevanB's Avatar
Hmm I tried hooking my poewr supply to an power strip recently, and the power strip just POPPED and turned off. Could this be an effect of me cutting off the "voltage selector switch" (usually sticks out of case next to power cord inlet)
Old 01-30-2004, 03:13 PM   #25
hawker's Avatar
yeah that could be a possibility, i found with mine (on my first one) that if i cut the switch off, or cut any off the internal wires going to various components, regardless of how many timse i re connected or resoldered those leads, it wouldn't work again, I know i resoldered them correctly, but it just wouldn't go. I got a new one, and the only thing I touch was the black and yellow leads and then connecting them up.
Old 01-30-2004, 03:15 PM   #26
KevanB's Avatar
yeah I forgot where they went to too. So Im pretty much screwed, I cant find where it went!!
Old 01-30-2004, 04:21 PM   #27
Send a message via ICQ to Barney Rubble
Some good info here guys if your interested.
Click Here
Barney Rubble is offline   Reply With Quote
Old 02-19-2005, 08:44 PM   #28
GReddy's Avatar
Send a message via AIM to GReddy
does anyone noe of any other sites that has more pics?
GReddy is offline   Reply With Quote
Old 02-19-2005, 08:49 PM   #29
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Its 300ma which comes out to 3A so it would not work for your application.
dgullickson is offline   Reply With Quote
Old 02-19-2005, 10:00 PM   #30
GReddy's Avatar
would this work?
+12 4.2a
+5 18a
does the +3v3 give out 3v?
Computer power supply used for charger power supply? 66Racer Radio and Electronics 7 05-25-2008 12:52 AM
Computer power supply semper Australian Racing 79 11-23-2007 12:35 PM
computer power supply koolkidd Electric On-Road 29 06-10-2007 09:53 AM
computer power supply hpipro321 Electric On-Road 4 09-01-2005 01:25 AM
Computer power supply Losi Jet Pilot Electric Off-Road 3 06-15-2005 06:51 AM
