Minimum Servo Specs for Touring Cars >
Old 02-19-2002, 08:55 PM
Default Minimum Servo Specs for Touring Cars
Guys:
I think its overkill, but I'm running an Aitronics 94257 in my tc3. Took it out of one of my old off-road gas trucks.
Specs on the 94257: torque 110, transit time .06.
What are the minimum servo specs that you recommend for 4wd electric touring cars?
Thanks,
YJ
yokomojo is offline
Old 02-19-2002, 09:04 PM
Fire's Avatar
min spec????
just anything above specs of those basic servos that come with the radio should work.
Fire is offline
Old 02-19-2002, 09:06 PM
Trips's Avatar
Trader Rating: 16 (100%+)
I don't think a servo belongs in a touring car unless it's speed is under .10 and its torque is above 80 oz.
Trips
Trips is offline
Old 02-19-2002, 09:19 PM
Speedo's Avatar
I have a JR .12 which is very smooth. I would say under .15 and at least 80 for torque
Speedo is offline
Old 02-19-2002, 11:56 PM
depends on drivers as well...
for newbies...a standard servo is good enough...
for high level enthusiates...why op for just a minimum...
vrcs is offline
Old 02-20-2002, 02:52 AM
Yokomo Fan's Avatar
Under .15 will do even for competition, theres no need for mega bucks servos.
Yokomo Fan is offline
Old 02-20-2002, 08:52 AM
Regional Moderator
Darkseid's Avatar
I ran for years with a standard servo. I always did well with them.
Now though I have switch to a servo with .09sec@114oz/in of torque.
Darkseid is offline
Old 02-20-2002, 12:18 PM
Cole Trickle's Avatar
Also remember to check the ESC's BEC voltage. If 6 volt, fine. If only 5 volt, then its equal to 25% less servo speed/torque. In this case, consider a new ESC or a servo with 7,2 volt FET wire. The KO Propo ones use to come with a description of how to connect.
Digital servos got better resolution and much better holding power.
Personally, I've used a standard servo for about a year. Then I got a digital one with 0,1 sek/60 deg. and 6,4 kg/cm torque. Very, very good. But it dont fit together with my new radio, so now I've ordered the KO PDS 2143 - 0,06 sek/60 deg and 9,5 kg/cm torque. Cant wait....
A point of view: At 40 km/h, your car is moving 11,11 meters/second. In 0,1 sec., it's moving more than a meter. A standard servo usually are around 0,2 sek/60 deg. A very good servo are around 0,1 sek/60 deg.
Cole Trickle is offline
Old 02-20-2002, 12:59 PM
Good point, Cole.
Here's the Airtronics numbers at 4.8V:
http://www.execulink.com/~rabrown/airser.htm
yokomojo is offline
Old 02-21-2002, 03:34 AM
I think this link better show the point about servo voltage. It's the popular Hitec HS-525BB, the specs are both at 6,0 volt and 4,8. And both in oz/in and kg/cm. Click on the link and choose HS-525BB. http://www.hitecrcd.com/Catalog/Servos/Servo_Index.html
Well, numbers are nice, but from the real world and about what's needed; When I went from a standard servo to a faster one (0,1 sec/60 deg and 6,4 kg/cm), I noticed:
In the beginning, I turned too early and hit the wall. After some practice, I was able to steer contra if the rear slided. I couldnt do that before. Also, going thrugh a chicane, before I couldnt change direction when I first was in the chikane. With the faster servo, correntions in the middle of the chikane was possible.
All in all, I think it's a very big difference. I also think this is one of the most important and overseen hop-ops. And best, and servo can be taken to another car...
Old 02-21-2002, 06:14 AM
CRASH's Avatar
Trader Rating: 26 (100%+)
If you are an experineced racer then faster and mor torque is better. If you are just beginning then a faster servo is not always good. A faster servo can make the car way to twitchy for a beginner. A stock servo is more then likely going to be just fine for a beginner.
CRASH is offline
Old 02-21-2002, 06:15 PM
Is the Hitec HS5625 a decent servo for a TC?(XXX-S) New to TC. Old 1/10-12 Pan Racer. LHS has them going on sale tomorrow for $49.95
MDM3 is offline
Old 02-21-2002, 07:13 PM
Looks pretty close to the 80/.15 rule above.
http://www.hitecrcd.com/Catalog/Servos/HS-5625.htm
And its digital
yokomojo is offline
Old 02-21-2002, 08:14 PM
Trader Rating: 82 (100%+)
im about to get a futaba servo - either a 9450 or 9402. i have an old 9402 that ive been using for 3+ years with no problems on my TC. do you guys have any reliability problems with a 9450? also, i saw a hitec servo programmer for hitec digital servos. will that work for with futaba digitals? is that programmer necessary for a digital servo? thanks for any info
marvi is offline
Old 02-21-2002, 08:41 PM
CRASH's Avatar
I have been using the 9402 for years and have never had one problem. Truly a great servo for on or off road.
CRASH is offline
