Old 08-13-2009, 03:36 AM   #1
Airflow's Avatar
Default Rear spool, any advantage?
Planning to use this set up for drag.
Will I loose rear grip? Or if I make sudden brake while turning,
will the car spin out? Has anyone here tried this setup?
Thanks in advance.
Airflow is offline   Reply With Quote
Old 08-13-2009, 03:55 AM   #2
tc3team's Avatar
A lot of drifters use spools in the rear for their setups, not good for racing though...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 08-13-2009, 04:06 AM   #3
Thanks in advance.
for drag i think you will be better or the same as a tight ball diff but if you need to trun a corner you will find it harder with a spool as it will not let the inner wheel rotate at a differant speed to the outer
sidecarphil1 is offline   Reply With Quote
Old 08-13-2009, 04:13 AM   #4
tc3team's Avatar
I'd be worried about the transmission - at least the diff offers a little bit of give in it, rather than the sudden rip of power/direct drive of a spool.
Guess it wouldnt do any harm to try it though?
I'm not really sure why i'm thinking it, but for drag the car might veer off to one side with a spool in the back if the car is unbalanced in some way.
Old 08-13-2009, 04:28 AM   #5
mike ivy's Avatar
Trader Rating: 50 (100%+)
What would happen if you put a oneway up front and a spool in the rear?
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 08-13-2009, 05:34 AM   #6
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
I do'nt know about now, but that setup is used in 1/8th onroad. I ran that setup in my 1/10th nitro 8 years ago with foam tires. A bit tricky to drive. It can only work with lots and lots of traction and on a bigger track. Nightmare to drive on smaller, dusty tracks so I swapped the rear spool for a diff.
Dan is offline   Reply With Quote
Old 08-13-2009, 06:48 AM   #7
nazwenhome's Avatar
Trader Rating: 33 (97%+)
1/8 car is more stable than 1/10th car. any how u do it, its still fast because of the grip. its just the matter of the drivers hand
if u're into hi-speed drift ep, then 1 way front with a spool like rear will better all rounder,at least for me. it'll be be easier to turn on hair pins it'll loose rear traction more on low speed and understeer on throttle response at hi-speed section. there's always possibility of spin out with this set up. but u can further refine it with chassis setups. to cope with this setups, experiment with softer rear spring, higher shock oil front and a higher gear ratio.
hope this helps.
Serpent S411 TE : ready to race
Tamiya TA05 VDF : sleeping mode
Align 450 sports v2 : tick-tock in progress
nazwenhome is offline   Reply With Quote
Old 08-13-2009, 07:38 AM   #8
oeoeo327's Avatar
Trader Rating: 74 (100%+)
+1 - I've tried that once (emphasis on ONCE...) Without a ton of traction it's almost an exercise in futility...
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 08-13-2009, 06:29 PM   #9
Airflow's Avatar
Ok thanks. Ill just put the spool up front.
I thought it would help out in quick launches in drag.
