Old 12-07-2009, 10:11 AM   #46
Jackster's Avatar
Trader Rating: 19 (100%+)
For those of you who don't know:
http://www.teamtekin.com/hotwire/ESCsetups/index.html
Jackster is offline   Reply With Quote
Old 01-02-2010, 04:29 PM   #47
blackdog's Avatar
Thumbs up In need of 21.5 vta set up with Tekin v203 software
Hi
I just downloaded the new software and Im kinda lost. I'm am looking for a base setting .car is a TC5, reedy lipo (5000) 35c with 21.5 novak and Im running vta in St.Catherines Ontario (Niagara indoor ) .Im not sure of the track size but it is a a far size track that changes every weekend.
I have set all base setting to what I had previously
Im going to use the 203 version ???
End RPM I set to 4000 and start RPM to 13000 I have no clue if this would be ok or not
Turbo ramp is at 2
LMK
Thanks in advance
Matt
blackdog is offline   Reply With Quote
Old 01-02-2010, 04:41 PM   #48
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
high end rpm will stretch the range if you need more you can lower it until you find what your looking for,it is something you need to play with.like Jim,randy and others have said start with timing boost to find your acceleration and then add turbo on the straight.what motor are you using.
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-02-2010, 04:49 PM   #49
blackdog's Avatar
A novak 21.5 SS pro with rs tekin
Old 01-02-2010, 05:49 PM   #50
Originally Posted by blackdog View Post
Hi
Turbo ramp is at 2
LMK
Thanks in advance
Matt
See your other post on the RS Sensored thread. You have the Start and End RPM's reversed here. The Start should be 4000 and End 13000. As listed in your question, your Timing Boost would literally be over with before it got started.
Aaron
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 01-19-2010, 09:21 PM   #51
rcman1993's Avatar
Trader Rating: 33 (100%+)
I need a setup for a off road 2wd buggy on carpet with a team epic 17.5 motor, it's the newest one. Need something with speed and punch. It's on a smaller track I guess you could say. I'm using the 203 software. Thanks for any help in advance
X-Factory X-6 Squared w/17.5 Duo 2, Tekin RS Pro, 3PK
AE, X-Factory, Tekin, Trinity, Futaba, Proline, JConcepts, Team Orion
AMS Raceway, Larrys RC
rcman1993 is offline   Reply With Quote
Old 05-17-2010, 11:39 AM   #52
Way2Evl's Avatar
Any updates? Lets keep this thread alive.
X-Ray T3|Tekin|KO Propo|Spektrum|Thunder Power|Hyperion|Sorex
www.speedworldraceway.com
Way2Evl is offline   Reply With Quote
Old 05-22-2010, 10:32 PM   #53
metalflakeking's Avatar
Hey, just picked up my first RSpro and love it. Here is a setup I used my first time out. I used a 17.5 motor in a 13.5 sedan class where no one is using electronic timing and got 2 extra laps on everybody in the main.
track:asphalt-rubber tire
grip:medium,sandy
car:tc5
motor:tekin 17.5 redline
motor timing:0
sensored only,Vegas203
FDR:6.21 (87spurx28pinion)
boost:50deg
start:1,425
end:5,997
turbo:10deg
delay:0.1
ramp:3.0
battery:4200 40c thunder power
After a 6 minute main at 87f ambient air temp the motor temerature scaned at 175 degrees. Faster straightaway speeds and same out of the hole as an untimed 13.5, what's not to love? two thumbs up for Tekin.
MAX SPEED
metalflakeking is offline   Reply With Quote
Old 05-23-2010, 04:35 PM   #54
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
grip:medium,sandy
car:tc5
motor timing:0
boost:50deg
start:1,425
end:5,997
turbo:10deg
delay:0.1
ramp:3.0
I think you are overtimed...50 timing boost over that short of an rpm range is way too much. 1500 +/- start rpm is fine for pan car, but in TC you should probably be closer to 5k for start or else you are always in the boost. Try 5-15K with everything else the same and I'll bet dimes to dollars your temps will drop with no performance loss.
-rocky b
flatspunout is offline   Reply With Quote
Old 05-23-2010, 05:23 PM   #55
Thanks for the suggestion. I am going to try it next time out. I have a feeling I will be playing with the Hotwire alot just to see what changes do what.
MAX SPEED
Old 05-23-2010, 05:28 PM   #56
cyclone x's Avatar
grip:high
car:xray t3
motor:tekin 10.5 redline
motor timing:0
boost:35deg
start:3300
end:13000
turbo:8deg
delay:0.1
ramp:3.0
battery:5200 40c SMC
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 05-23-2010, 05:33 PM   #57
how can anyone have let this thread die? tekin rs thread is still choked full.
+1 for this thread existing and +1 for being revived
benben10 is offline   Reply With Quote
Old 05-25-2010, 02:23 PM   #58
Way2Evl's Avatar
Please keep us updated. Interested to know the results .
Old 05-26-2010, 04:50 PM   #59
Way2Evl's Avatar
Is drag brake bad for a 17.5t setup. I was on the Tekin site and I saw that a pro was using 20 drag brake on his setup. But most at local track say drag brake is bad for 17.5 because the motor isn't that fast and you should harly ever need it. They say it will just slow you down in the corners on a technical track that we run on. What are your thoughts?
Old 05-26-2010, 05:10 PM   #60
Micro-E's Avatar
17.5 w/ Tekin RS not fast?!? hmmm. I tried with different levels of DB and without, and I settled on 15. Got my best laptimes to date...
YMMV
- Erik
Micro-E is offline   Reply With Quote
