Old 08-14-2009, 12:40 AM   #16
xevias's Avatar
You will find team driver set ups on Facebook. Look up Tekin Racing.
xevias is offline   Reply With Quote
Old 08-14-2009, 07:23 AM   #17
avs
avs's Avatar
Originally Posted by Skitee View Post
Ii think the guys just thought that all of these setups would clog the RS INFO/TECH thread up, so they did thi solely for the "TURBO" setups.
no, i think the other way around. all the questions make the setups hard to find!
avs is offline   Reply With Quote
Old 08-18-2009, 12:26 PM   #18
2wdrive's Avatar
very interesting thread, but instead of SIZE of the track in smal, medium or large i would rather find it more interesting to see the lenght of the straight part of the track in feet or meters.
My reason for this is that sometimes i see people writting that they run on a HUGE track and when i read further and see how many feet the straight part is i can't help but think that it isn't such a huge distance?
That is why i think the lenght of the straight part of the circuit would be more interesting for someone seeking for a setup for his track as the lenght of the straight part is crucial for the turbo and maximum speed? (some already did this).
2wdrive is offline   Reply With Quote
Old 08-19-2009, 11:07 AM   #19
Can I be included in getting this version?
[email protected]
RMP750 is offline   Reply With Quote
Old 08-24-2009, 08:14 AM   #20
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Same 23 images the last couple of days. We need more 17.5 suggestions.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-24-2009, 11:19 AM   #21
bukil's Avatar
Trader Rating: 39 (100%+)
Camarillo Track:
Track surface - asphalt
Traction (h/m/l) - med to high
Size (s/m/l) - medium to large
Class - 13.5
Chassis - Cyclone TC
ESC - Tekin RS
Motor - Tekin 13.5
Motor timing - 10
Gearing - 5.62 FDR
Battery - TP 5200 40C
Firmware - v200
Drag brake - 0
Brake - 100
Limiter - none
Neutral - 10
Volt cut off - 6.4
Motor type - Brushless FWD only
Throttle profile - 3
Sensored/dual - Sensored
Push control - none
Timing boost - 10-12
Turbo boost - Max
Turbo delay - 0.5
Enjoy.
bukil is offline   Reply With Quote
Old 08-24-2009, 08:50 PM   #22
mjc168's Avatar
Trader Rating: 25 (100%+)
Any FDR recommandation for SpeedPassion 11.5t motor?
http://www.pprcc.com/
1/10 On-road Touring: Schumacher MI3 + Tekin RS Pro + Orca RX-1 11.5t BL Motor
1/10 On-road Touring: Xray T3 2011 + Tekin RS Pro + Tekin Redline 10.5t BL Motor
mjc168 is offline   Reply With Quote
Old 08-25-2009, 07:59 AM   #23
Start at 6.5 and work your way towards 6 at small increments.
Old 08-25-2009, 08:05 AM   #24
Default set-up
I am new to facebook I have been on tekin racing how do you get to the set ups thanks
mshap33 is offline   Reply With Quote
Old 08-25-2009, 08:41 AM   #25
I think you will see some more set ups for 17.5 in a few weeks.
I am running the RS with a 17.5 hacker e40 motor, but offroad doesn't
start for a few weeks we are just finishing oval. I know a few guys at our
track for onroad tc 17.5 will be running it. I am not sure how many others
are running it for offroad yet.
Dynodan22
dynodan22 is offline   Reply With Quote
Old 08-25-2009, 08:52 AM   #26
Go to their image gallery. There are screenshots of setup sheets there.
Old 08-25-2009, 08:55 AM   #27
I don't think my JRX-S Type R will be doing much offroad.
I'll be doing some serious testing Friday night and Saturday to try and get this thing figured out for my local track. I'll post my setups once I get them dialed in.
Old 08-25-2009, 03:06 PM   #28
Low_E's Avatar
Send a message via MSN to Low_E
it would be so easy if there was a profile-save-function in the Tekin-software.
SO that you can simply choose between some profiles you have made earlier on, in stead of having to copy all data from a paper sheet.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 08-25-2009, 03:30 PM   #29
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
That function is in the works...
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-25-2009, 06:16 PM   #30
mjc168's Avatar
FDR 6.5??? before i am using v200, i run FDR 5.1 for our local outdoor track. for a bigger track I will run FDR 4.7. Do you think FDR 6 abit too high? Thanks
