Best 13.5 motor?
Oh man, this is one of those threads when everyone is thinking their motor is the best....... Just look around your track and try different things (borrow a motor for one run). Every motor reacts differently to the different tracks and gearing. BTW all of those you have mentioned are good so make your pick.
I know the GM are very quick like the novak's but id recomend the GM as they run cooler with the cooling holes in the can.
I like my Speed Passion simply because it's designed to work with the LPF speedo and suits my regular track.
There are guys at my club running GM and Novak motors on SP ESCs with good results.
Horses for courses I would imagine.
prince first batch...
They are actually like 10.5T
i have to say after testing the speed passion , LRP and the GM the GM is best even with the LRP stock spec , it runs cooler and you can gear it harder then the other 2 i tried
and if you get one from HK modelbouw in germany they are only €49
but if you want i have an LRP that i have used once you can buy from me for a good price
PRINCE!!!! first batch one mean motor.13.5, anyone try the 10.5 prince? any good?
cheers
Ricky Copsey
cheers
Ricky Copsey
whats this "HK Modelbouw in germany"?
Good price
Good price
http://www.hk-modellbau.com/default.asp?mshop=1
ere you go
but i do live in holland and they dont take paypal , bank transfer only and their english is not good
but they are cheap and their postage is per box no matter what you have in it (within reason)
ere you go
Ran my 13.5 Fantom tonight in TC and kept up with a 4600Castle setup. I'm very impressed with my Fantom. Just my .02!
