Old 08-11-2009, 05:10 AM   #1
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Default Is Quantum 1, 2 or 3 with Spektrum sill a problem?
I used to run a QC2 and a Spektrum 3000 Rx...I remember it would drop power to my personal and I had to run a cap in my reciever. Is this still an issue.?..I now have the mini 3500 Rxs.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 08-11-2009, 05:35 AM   #2
niznai's Avatar
I'd be interested to know what the problem you experienced was. I am running a QC3 at the moment with a spektrum DX3 and a SR3500 receiver and didn't have any problems I can identify. I felt a couple of times like the car had lost reception for a fraction of a second but I wasn't sure. Could this be a symptom? Where did you run the capacitor?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-11-2009, 05:45 AM   #3
Skitee's Avatar
Probably in the RX so that the BEC doesn't drop out
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 08-11-2009, 07:15 AM   #4
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
The QC2 I had cut out with the SR3100, the 3500, and even a regular airtronics rx. A 3300uF cap fixed the issue, but I traded it for a GTX, which has been flawless.
I still use an old QC1 in my Mini, with the SR3100 and JR4750 servo, but I need to use a 10,000uF cap in the Rx for that.. Thankfully there's plenty of room in the back of the chassis!
The issue was very evident when I flicked the steering really quick. The AMB and Rx lights would dim or go out, and then the Rx takes a second to reestablish a connection. Not good when racing!
I'm sure the QC3 has resolved the problem, as it's brand new and there's no excuse to not have a decent BEC current for today's electrics. My Sphere TC works fine with anything.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 08-11-2009, 07:19 AM   #5
What the problem was is the Spektrum reciever (at least the 3000) was that it draws more than a typical reciever. And the LRP BEC is lower voltage than most high end escS (I believe 5v) and when you have a high power servo, personal and the Spektrum upon accelleration the voltage will be too low for everyhting to run at once and your personal may not count, or the servo may stop suddenly.
Old 08-11-2009, 07:24 AM   #6
niznai's Avatar
So the fix was to stick a capacitor in the receiver in one of the unused channel pins between the + and - pins?
Team Greasy Weasel
Old 08-11-2009, 07:34 AM   #7
Yep...I just didn't know if that was still an issue with the newer Spektrum recievers.
Old 08-11-2009, 09:27 AM   #8
Jam-ehz's Avatar
I think it's more the current drawn from the ESC than the voltage itself.
I'm sure I've read the QC1/2 do 5.5V (which is fine, since the Spek Rx can operate at under 3V) but only at a rate of 1.8A sustained. The Rx on its own likely brings it nearly to the limit, add the AMB and some servo movement and the current drawn is easily too much to sustain without a capacitor, so the voltage drops out.
The GTX and current ESC's all sustain 3.0 to [email protected]
Meanwhile my "crappy" LRP Runner had absolutely no problems running the same equipment.. go figure..
Old 08-11-2009, 09:38 AM   #9
niznai's Avatar
QC 3 BEC does 6V/3.5A
Team Greasy Weasel
