Old 08-10-2009, 05:45 PM   #1
mattyau's Avatar
Send a message via MSN to mattyau Send a message via Yahoo to mattyau
Default LRP Pulsar 3 Charger Settings 4 Lipo
could someone with this charger tell me what ware the charge settings for charging a Intellect 5000mah 40C Lipo
.:T2'009:.
mattyau is offline   Reply With Quote
Old 08-10-2009, 06:45 PM   #2
AE-Reedy
Just be sure the charger is set up in "lipo" mode and then charge at 5 amps.
Sean Cochran is offline   Reply With Quote
Old 08-11-2009, 06:44 PM   #3
mattyau's Avatar
Cheers, does my power supply need more then a 2.5 amp output
.:T2'009:.
Old 08-12-2009, 04:16 PM   #4
AE-Reedy
If that is all you power supply will put out, then you will only be able to charge at a that level. Shouldn't make any performance difference but will take a long time to charge.
