Old 08-10-2009, 02:48 PM   #1
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Questions?? What rubber tire's to run on asphalt track?
Ok here is the senario, here in Tx we run the RP36 tires on an asphalt preped track for are 1/10 electric class. Now since are local hobbie shop is unable to get them any more(not being made anymore) were needing a new rubber tire. I seen that "Muchmore" has a very good selection of tires out Sweeps and Absolute TC rubbers. Has anyone tried these on asphalt if so how do they hold up? Are track temp varies from 110-140+.
SWEEPS:
http://www3.towerhobbies.com/cgi-bin...?&I=LXUSN9&P=7
ASOLUTE TC
http://www3.towerhobbies.com/cgi-bin...?&I=LXVFA3&P=7
What rubber tire's to run on asphalt track?-mmrc2204.jpg   What rubber tire's to run on asphalt track?-mmrc2218.jpg
BIG DADDY8 is offline   Reply With Quote
Old 08-10-2009, 03:21 PM   #2
Yeti35's Avatar
Be aware you have to still glue the Sweeps, since they are only mounted to the rim, not glued. I have some Absolutes in my box now that I have not used yet. They are truely pre mounts in that they are glued to the rim. I hear the tires are good but the wheels are a bit brittle and break easily if you tend to hit things. Good thing with the Sweeps not being glued is you can change out the inserts for something else before you use them.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-10-2009, 03:27 PM   #3
BIG DADDY8's Avatar
That's good to know. Were trying to find another tire for are shop to carry that's ready to run out of the pack. Just trying to find the closest tire to the RP36's.
Old 08-10-2009, 03:27 PM   #4
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
I've heard that the new Jaco Blues are really good....
Alex
hound_dogs_01 is offline   Reply With Quote
Old 08-10-2009, 03:32 PM   #5
Yeti35's Avatar
The blues are only a 32 and if they are looking for a hotter condition tire Jaco only does 32.
22 3.0SR
Old 08-10-2009, 03:34 PM   #6
BIG DADDY8's Avatar
I have a couple sets of jaco blues and YES they are to soft for the hot weather. I have a NIP that i'll probably never use until the winter maybe.
Old 08-10-2009, 03:36 PM   #7
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Alex
Which are the new jacos? Rubberz or Prism?
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 08-10-2009, 03:36 PM   #8
Yeti35's Avatar
Your best bet if you shop can get ahold of them is Sorex 36R's. Sorex are just awesome tires period.
22 3.0SR
Old 08-10-2009, 03:37 PM   #9
Miller1's Avatar
Trader Rating: 36 (100%+)
+1!!!!!
Miller1 is offline   Reply With Quote
Old 08-10-2009, 03:37 PM   #10
you dont have the new ones.... jaco hasnt released them yet.... they were tested at the beat the heat in Memphis a few months ago and from what I've heard from the guys that ran down there they performed flawlessly...
jaco has redesigned the blues....
Alex
Old 08-10-2009, 03:40 PM   #11
BIG DADDY8's Avatar
Alex
Are they gonna be a harder compound or a better medium compound?
Old 08-10-2009, 03:41 PM   #12
BIG DADDY8's Avatar
Can you get them already mounted?
Old 08-10-2009, 03:44 PM   #13
Yeti35's Avatar
Yes, Speedmind wheels which have been pretty durable imo. There is also Speed World that has a deal with Jaco mounting the Sorex Tires on the new Jaco Prism wheels. I have yet to run any of those and you would have to call Speed World direct to order them.
22 3.0SR
Old 08-10-2009, 03:46 PM   #14
RC MARKET's Avatar
SOREX 32 ,36 or 40 R
Insert Yokomo ZR-039M ( if no traction can use RIDE MS24-C30 or C20 Or lower grip Orion JB Foam insert )
Wheel Yokomo TW-1012-2 or Y2
Traction compound
Trinity EPIC Tire Tweak 2000 # 6684
Paragon FX2
http://rcmarket.com.hk/index.php?cPath=55
Sweep tire lost 1 sec 1 lap
RC MARKET is offline   Reply With Quote
Old 08-10-2009, 03:48 PM   #15
I'm not really sure.... I know they have a taller side wall and the compound is "better" from what i've heard
Alex
Rubber tires for dummies rayhuang Electric On-Road 391 06-02-2012 08:37 AM
Major races would fewer be better? teammidget lilB Electric On-Road 69 12-02-2008 08:55 PM
KING OF TOURING RACE HD-F1 Georgia Racing 114 10-20-2007 09:22 AM
Great TC Class (Foam modified outdoors) PhatPat Electric On-Road 26 06-10-2005 09:26 PM
Should racers be required to move out of stock at a certain level? TSB Northwest Racers 94 09-28-2004 10:58 PM
Spec [email protected] national level races sponger Electric On-Road 56 09-19-2004 08:02 AM
