KO Propo EX10 Helios >
Old 01-22-2004, 04:37 AM
octavio's Avatar
Thumbs up KO Propo EX10 Helios
I just bought this great radio, and am puzzeled a bit about the manual (not the best english), and the lots and lots of setup - possibilities.
So, I would like to start this thread for sharing do' s and dont's.
and what are the most useful setup alterations.
anyone starts ??
octavio is offline
Old 01-22-2004, 04:59 AM
Cole Trickle's Avatar
Not that I got one myself, but I would simply start with the basics; Servo reversing, EPA TH/ST, TH offset, stuff like that.
The other things, I would leave default.
Afterward, I would experiment with the rest, one at the time.
I would use HRS, if the rest of the equipment allows me too.
Cole Trickle is offline
Old 01-23-2004, 12:08 AM
octavio's Avatar
thx Cole for yr comments.
I suppose HRS can only be used in combination with a digital servo. On my Micro, I have a analog servo, thus have set it at Normal response.
On my Assassin, i have a digital one, so I'll have to put it on High speed.
The manual refers also to STEERING CURVE, I suppose this is what normally is referred to as EXPOnantial steering ?
The autostart is not clear to me. this happens only once after pulling the trigger at the startsignal. but what means "preset F " , and TH:POS 5% ? the higher the percentage, the more power you get at the first start? so why not put it at 100?
octavio is offline
Old 01-23-2004, 12:23 AM
I believe it is - because it is on my Presto.
Old 01-23-2004, 12:24 AM
Servos, modes versus equipment - click here
It's from the "KO PROPO EX-10 Helios q's" thread. You might find some usefull information there.
Old 01-23-2004, 03:27 AM
lem2's Avatar
Default Batteries
I'm usingGP 1300 NiMh AA's and they don't last for 10 minutes.
Are youusing 2000 AA's?
Thanks!!
Lem
lem2 is offline
Old 01-23-2004, 04:17 AM
Default Re: Batteries
Thanks!!
Lem
I dont got a Helios myself, but 10 minutes are way too low. Even with 2000's it would only last 15-17 minutes !
If your GP1300 aint new, I would discharge them totally and give them a full charge.
Maybe one of your cells are dead....
How do you charge them? How long do it take? Do one of the cells get warm/hot before the others?
Old 01-23-2004, 08:37 AM
lem2's Avatar
Default Re: Re: Batteries
I used them in my PResto and they are about 4 months old, will cycle them to give them a boost. But I charge them in my Quasar at 3mV per cell at .9amps? Am i Wrong?
Thanks!! Lem
lem2 is offline
