Old 08-09-2009, 04:41 PM   #1
capturefx's Avatar
Default help! esc problems duratrax 8t pro
everyone please help i have just finished my xray t2 pro and the duratrax 8t pro esc that i bought for it seems to be not working.. what happens is that the throttle works but im not getting any steering( its like moving but doesnt seem to be getting enough power) but when i took my old esc and tried it everything works.. i dont get it. help
http://manuals.hobbico.com/dtx/dtxm1080-manual.pdf
capturefx is offline   Reply With Quote
Old 08-09-2009, 04:48 PM   #2
Maybell's Avatar
Your problem could be a bad BEC in the speed control, channel 1 could be bad in your reciever or it could be the servo...
If you have another servo to try then try that first....if the servo is ok try plugging your speed control into channel 1 and see if your throttle works...
If the servo and reciever are ok then a bad speed control BEC must be the problem...
Hope this helps..
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 08-09-2009, 04:56 PM   #3
capturefx's Avatar
yeah i tried that i pluged in a different servo and it dint work, but if i take my old esc and install it , everything works fine radio esc motor perfect , it might be a bad bec, is there anyother way to check for a bad bec.?
Old 08-09-2009, 05:15 PM   #4
Maybell's Avatar
You could try a Castle BEC or something like that but it sounds like your problem has to be a bad BEC...
Old 08-09-2009, 05:43 PM   #5
capturefx's Avatar
ok thanks but the bec in this one is internal, do i have to replace it or just get and external one?
