Old 08-07-2009, 04:43 AM   #16
niznai's Avatar
Yes, you get the idea. That's how they align real cars' wheels, only they use lasers instead of rulers.
Yes it will.
That's why you don't.
The idea however is to get this misalignment to be as small as possible (you can only have zero if you don't have any suspension).
This is what you're practically trying to achieve.
Equal misalignment at fully compressed suspension and at fully extended suspension. At the same time, this misalignment has to be the absolute minimum it can be.
This will only happen if you have the steering rod outer end (the part attached to the steering block) travel equally up and down (as the suspension travels between full droop and full compression) when compared to the inner end (the end attached to the steering/drag link).
This might mean that you have to shim the balljoints at both ends of the steering rod.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-08-2009, 05:44 AM   #17
Airflow's Avatar
Thanks man.
Airflow is offline   Reply With Quote
Old 08-09-2009, 12:48 AM   #18
noob, here... does heat affect grip on rc slicks? as in a real (1:1) race car?....
toe also plays a part in keeping the wheels hot whether it be the front or rear.
my .02
b2ian is offline   Reply With Quote
Old 08-10-2009, 04:21 AM   #19
cyanyde's Avatar
my .02
Yes. Heat affects traction. Be it tire heat or track temp. Just like the real cars.
cyanyde is offline   Reply With Quote
