Old 08-06-2009, 08:20 AM   #16
Skiddins's Avatar
Err, has any of this answered your question Ricky?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 08-07-2009, 04:07 PM   #17
Skiddins's Avatar
While we're here, anyone know aht HPI pinks are really?
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-21-2009, 07:43 PM   #18
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Skiddins
18.0 lbs......
Arv.
EA MOTORSPORTS// KO PROPO// ORCA// 180 RACEWAY
RCFREAK is offline   Reply With Quote
Old 10-21-2009, 08:08 PM   #19
linger's Avatar
Originally Posted by RCFREAK View Post
18.0 lbs......
Actually HPI Pink measures at 16.79 despite whatever it says on the label!
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 10-21-2009, 08:12 PM   #20
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Is there not a "proven" chart showing the pound ratings for all of the black xray springs?
mrrcguy is offline   Reply With Quote
Old 10-21-2009, 08:12 PM   #21
RCFREAK's Avatar
how did you figure ?
Arv.
Old 10-21-2009, 08:58 PM   #22
awth's Avatar
Does the HPI HB springs fit on the Xray shocks?
Have anyone try? Do they work ok?
Alan
- Xray T3 EU & T2 009 EU
- Assoicated 12R5
awth is offline   Reply With Quote
Old 10-21-2009, 10:26 PM   #23
linger's Avatar
Xray springs what does the 2.4/2.6 equal in pound/wt?-hpi-pink.jpg
Old 10-22-2009, 06:58 AM   #24
Skiddins's Avatar
Made this up a while back, not perfect but closer than the manufactures!;
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-22-2009, 07:12 AM   #25
TRF415boy's Avatar
HPI gold and silver are indeed linear (see pics). An averaged measured value of 17.49 and 16.21 lb/in respectively. A little bit off from published values of 19.04 and 16.91 lb/in. See the Tryhard website for other measured springs.
Sorry to contradict BUT...
Your graphs both show that at the very beginning the rate deviates from your calculated curve.
This is where the different makes and springs designs have their differences.
You CANNOT ignore the first 5-6mm of the curve because that's where the springs are most of the time when the car's on the track.
TRF415boy is offline   Reply With Quote
Old 10-22-2009, 08:42 AM   #26
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
(.05" = 1.27mm)
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-22-2009, 10:33 AM   #27
linger's Avatar
The test equipment has perfectly flat upper and lower platens that compress the spring. However, when you place the spring on the lower platen, the top of the spring is never 100% flat and parallel relative to the bottom. The curve at the beginning is just the spring settling into the fixture.
If you look at the HPI gold chart - this "nonlinear" region is about 0.01" or about 0.25mm. If you do a best fit to a perfect linear line - the R squared value is 0.9999. That spring is 99.99% linear.
Old 10-22-2009, 04:23 PM   #28
when i measured the black xray springs they were linear, to convert from Xray "C" which is N/mm to lb/in you multiply by 5.71.
http://forum.teamxray.com/viewtopic.php?t=9144
gameover is offline   Reply With Quote
Old 10-27-2009, 11:01 AM   #29
seaball's Avatar
i finally measured a set as well. pretty solid:
SPRING - RATE - DELTA (L/R)
XR - 2.2 - 12.4 - 0.06
XR - 2.4 - 14.1 - 0.02
XR - 2.6 - 15.1 - 0.10
XR - 2.8 - 16.3 - 0.12
XR - 3.0 - 17.5 - 0.27
XR - 3.2 - 18.4 - 0.18
XR - 3.4 - 20.0 - 0.01
Old 12-27-2009, 05:56 PM   #30
Skiddins's Avatar
Hate to open up this can of worms again, but does anyone know the actual rate of the Tamiya coloured springs, by that I mean measured, not what it say's on the packet
Particularly interested in Tamiya White, Yellow and Blue (as these are the springs I see used a lot.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
