Carbide Cutter for AC Cobra tire Lathe >
Old 01-22-2004, 11:13 AM
  #16
Default Carbide Cutter for AC Cobra Tire Lathe
Acrcracer,
I just saw the Typhoon Burr like you bought from MicroMark at Lowe's at lunch time. Like you said, it has a 1/4 shank.
Brant is offline
Old 01-23-2004, 02:45 AM
  #17
akrcracer's Avatar
So what's the price for burr at Lowes?
akrcracer is offline
Old 01-23-2004, 06:20 AM
  #18
Default Price at Lowe's
$17.97 plus tax or $19.28 total
Brant is offline
Old 01-23-2004, 12:15 PM
  #19
Trader Rating: 72 (100%+)
brant ,
did you get one,, how does it work?
also do you have a part number ,, for one that cuts coarse and one fine?
i be racing tomorrow out of state,, but i want to check at lowes sunday on getting one. i assume they are located by the drill bits and stuff or are they located somewhere else in the store.
thanks
BIGDON
BIGDON18 is offline
Old 01-23-2004, 01:35 PM
  #20
Default Lowe's Typhoon Burr
Yes, I got one and used it to cut 4 touring car and 4 1/12 scale tires. I bought the fine one. It worked great. No smoke from the lathe, no melted globs like the snake skin cutter. I was able to cut from 2.550 to 2.390 in one pass really cranking on the feed. I believe I could of gone deeper on the depth of cut with the same results.
I have the package at home so I don't know the part number. I believe the brand is Freedom. It was by the dremel tools in the tool section. You will spot it easily, it was the only thing there that had a 1/4 shank.
Brant is offline
Old 01-23-2004, 03:22 PM
  #21
man ,, thats great news,,
i know what you mean on the gumming up the snake skin cutter,, i have to blow mine off with the air hose after every tire,, special when cutting purples, reds and whites.
BIGDON
BIGDON18 is offline
