Old 06-02-2012, 05:32 PM   #781
macavant's Avatar
Trader Rating: 64 (100%+)
With the AE battery cup mod - my 2S 5000 packs fit fine.
likes the oldskool RC action...
F201☆F104WGP☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01.G6-01.SandScorcher☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 06-04-2012, 07:19 PM   #782
aquito's Avatar
What is the AE battery cup mod?
aquito is offline   Reply With Quote
Old 06-12-2012, 05:53 PM   #783
Default Swaybars
Hi Guys, new to touring cars and just picked up a JL-10e and was wondering if someone knows where a swaybar kit can be found? I see no listing from Ofna, and no posts where they can be obtained. Thanks for your help-Russ
russmustar is offline   Reply With Quote
Old 06-13-2012, 06:51 AM   #784
try nitrohouse.com
JJBTEXAS is offline   Reply With Quote
Old 06-13-2012, 05:44 PM   #785
Default Swaybar
No listing in option parts or kit parts. In early listings on this car, it was mentioned that it was very similar to an ABC car. Anyone know what model that would be? Thanks-Russ
Old 06-14-2012, 12:21 AM   #786
macavant's Avatar
A mod that allows a more convenient way to mount batteries on the JL10. I used the AE cups along with Velcro straps and even 2S 5000mah GensAce packs fit fine.
http://www3.towerhobbies.com/cgi-bin...P?I=LX2778&P=8
Old 06-16-2012, 09:43 PM   #787
What FDR should be I use with a brushless motor?
I am planning to installed a SV2 4600kw in my JL10e when it comes in. Running the stock 82T spur could I run either a 19T or 23T without overheating the motor or the ESC.
Stampede 2WD - Slash 4x4 - JL10e
Mandetiger is offline   Reply With Quote
Old 06-17-2012, 04:29 PM   #788
Default Black shock springs
Hi Guys-Does anyone here know where the stock JL-10 E (black) springs compare as far as the other ones that Ofna sells? I purchased P/N 38490 spring set which has 6pr w/ratings, but no black ones. I cannot find a listing that tells me such info anywhere. Thanks in advance for your help. Later-Russ
Old 06-19-2012, 06:10 AM   #789
Finally pretty much got it done! Don
Ofna JL-10 E-p1010001-6.jpg   Ofna JL-10 E-p1010002-6.jpg   Ofna JL-10 E-p1010003-5.jpg   Ofna JL-10 E-p1010004-2.jpg
DLS II is offline   Reply With Quote
Old 06-24-2012, 10:24 PM   #790
I was fitting a BMW 328 (Hpi) to my JL10e and I had to take the foam bumper off to make the front wheels line up. Has anybody else had to take the foam bumper off to fit some bodies?
Old 06-24-2012, 10:30 PM   #791
What body is that?
Old 06-25-2012, 06:59 AM   #792
Protoform J71
Old 06-25-2012, 08:27 AM   #793
macavant's Avatar
I had to trim the foam bumper to make an HPI Mclaren body fit. The initial cuts were done with an X-acto knife and final sanding with a Dremel sanding drum. I kept the 3 mounting posts/points intact.
Old 06-28-2012, 05:27 PM   #794
jboquire's Avatar
Trader Rating: 21 (100%+)
Default RCGT gearing help
Just received my JL10 today, what gearing do you guys recommend for non boosted 17.5 class?. I read that the FDR should be around 3.5 but that means I would need a 59T on 48 pitch, not sure anyone makes one.
Thanks in advance, jb
jboquire is offline   Reply With Quote
Old 06-29-2012, 10:22 AM   #795
Robinson makes a 60T. Also a 55T and some even smaller.
Kevin Marcy is offline   Reply With Quote
Picco .12 JL Red Dot & 30% heeltoedrver Nitro Off-Road 14 01-22-2009 07:22 PM
help me pick a engine LOW ET Onroad Nitro Engine Zone 19 12-27-2007 06:36 AM
