Old 03-28-2011, 03:30 PM   #616
The car can handle it-be prepared that is a lot of motor! Don
DLS II is offline   Reply With Quote
Old 03-28-2011, 05:05 PM   #617
TD-Ent's Avatar
Trader Rating: 75 (99%+)
It's not the motor/car combo you need to worry about, it's the car/curb combo you are inevitably headed for.
On a serious note, what ESC are you running? I'd start with the ESC turned back as far as it can go, and limit your EPA on your radio to 75% and then just keep turning everything up from there.
>> www.td-enterprise.com -- 63/37 Solder Kits <<
>> Team Durango - Savox - Speed Passion - Avid <<
TD-Ent is offline   Reply With Quote
Old 03-28-2011, 05:24 PM   #618
macavant's Avatar
Trader Rating: 64 (100%+)
Originally Posted by e123 View Post
I'm curious about the 5.5 because I have one I'm not using right now.
I was running a Castle 5700KV (3.5T) in my JL up until this week. It handled the setup fine. Diff rebuilds are common (@ least with my kit) with the 5700KV motor (2S max). I dropped an EZRUN 60A with a 6000KV 5.5T victory motor in there this past weekend. Ran it today - on 2S it handles it just fine. On 3S - it caught a bit of a bump, went airborne and it flipped over. It landed on its lid and slid down about 20 feet. My radio showed a max RPM of 20,235. I'm going back to 2S until I find a smoother surface to run the car on.
likes the oldskool RC action...
F201☆F104WGP☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01.G6-01.SandScorcher☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 03-28-2011, 05:28 PM   #619
Send a message via Yahoo to e123
Yup, I have had some previous issues with the car/curb combo running that motor! Hopefully I will be ok in a big, open area. But I'm sure I will find something to hit. Not sure on the ESC yet but it will probably be a 60a ezrun I have already. Any ideas how fast this car will be with that setup?
e123 is offline   Reply With Quote
Old 04-17-2011, 06:33 PM   #620
Default Setup needed for Parking lot
Need a quick setup (alignment and gearing) for parking lot running. Setting up a small course, nothing major but corners are tight. Just finished putting the car together, former 1/12 driver from years ago, but I hate the servo saver and battery tray on this thing. Also wasn't too impressed with the hex hubs and pins - ended up tightening the wheel nuts to push the pins into the hex hubs to seat them. Not sure if that was the right thing to do but it got rid of the wobble.
Any good source for spare stuff like front end pieces, bearings etc?
Thanks all!
Chasracer is offline   Reply With Quote
Old 04-17-2011, 07:33 PM   #621
kael's Avatar
http://nitrohouse.com has all the parts. Save your money and get bearings from avidrc.com.
Battery "cups": Yes, the stock ones suck, replace them with these:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2778
Gearing is the major thing, the car was geared for brushed, with brushless it feels like slow motion with the stock gears.
Find our what final drive ratio is good for your track. The internal ratio is 2.5 on the JL10. A good 48p spur is 69 tooth, plan on getting pinions in the 30-40 range. You can get smaller spurs, but not much.
What class/motor are you running?
\V/, Live Long and Prosper
kael is offline   Reply With Quote
Old 04-17-2011, 08:51 PM   #622
builthatch's Avatar
Send a message via AIM to builthatch
quick questions for you guys. what a great thread!
should i replace the diff balls from the start with something harder?
are there better, more durable dampers available? i'm looking for something adjustable and robust.
thanks.
builthatch is offline   Reply With Quote
Old 04-17-2011, 08:54 PM   #623
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
i am shopping for one of these now. what pinion/spur would i need for a 4.0 fdr?
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: [email protected]
looper is offline   Reply With Quote
Old 04-17-2011, 09:01 PM   #624
builthatch's Avatar
(88/55)*2.50=4.00 FDR
Old 04-17-2011, 09:08 PM   #625
looper's Avatar
holy smack. do they make pinions that big and would that gearing fit in the car?
Old 04-17-2011, 09:15 PM   #626
builthatch's Avatar
D Starks was running 88/53 for ~4.1
Originally Posted by D Starks View Post
64 pitch. 88 tooth spur, 53 tooth pinion.
Are you running RCGT at West Coast?
if there isn't a 55t available (i dunno, i was just doing the math based on D Starks's post), you could run 84/53, 69/43, etc.
in addition to my last questions, along with ordering extra arms, should i order
or
Old 04-18-2011, 12:19 PM   #627
It's just a bunch of us at work setting up a small track in the back parking area - so no known information to go on right now. Figure size-wise, not a whole lot more than a typical indoor carpet track - main straight is about 130-135 feet long. Have a couple of brushless motors and just tried out the car for the first time, off the line not too bad but pulling the straight not so quick. Need some additional adjustments to ride height and suspension settings. Right now, stock 82 spur with a 19 pinion and the 2.50 equates to a 10.78? I am thinking something in the 6.5 - 7.5 range would be a lot better.
Thanks for the tips!
Old 04-18-2011, 12:26 PM   #628
Default Spur Gears - what make fits?
Sorry but can someone tell me what brand of spur gear fits this puppy? The parts list I see on nitrohouse only list the stock 82 unit.
Thanks again!
Old 04-18-2011, 07:18 PM   #629
builthatch's Avatar
thanks.
or
bumpin' for these. i'm trying to complete my order but i want to get feedback before i do. if possible, lulz.
thanks.
Old 04-18-2011, 08:41 PM   #630
Smile Ass-end or dragging my tail??
Made a few runs and at this rate I'll need a new chassis plate next week! So what's the hot tip for setting the ride height and which shock oils to use? Car seems to handle fairly well although I am still pretty rusty. Back end likes to come around a bit more that I prefer but again suspension settings are off in my opinion. Any numbers for front and rear toe settings? Sitting still, the camber setting is amazing with less than 50% of the tire making contact with the pavement. Shocks are obviously messed up as rebound rates just bouncing the chassis a bit are different from side to side. A lot of tuning to do so if you have any tips or ideas toss them out here.
Thanks!
Picco .12 JL Red Dot & 30% heeltoedrver Nitro Off-Road 14 01-22-2009 07:22 PM
help me pick a engine LOW ET Onroad Nitro Engine Zone 19 12-27-2007 06:36 AM
