Old 03-08-2011, 03:47 PM   #601
kael's Avatar
Originally Posted by DLS II View Post
Are the droop screws going to be a problem with digging into the chassis? Are there any other "problem" areas I need to be aware of? Thanks, Don
Haven't had any issues with the droop screws myself.
I had issues with the supplied diff screws, broke a couple in the front diff, probably from running a little tight.
hexcrews.com has some higher quality screws that I've been using.
Only issue I have with the car is the diffs, they like to loosen up. Aside from the silly battery holders that is.
\V/, Live Long and Prosper
kael is offline   Reply With Quote
Old 03-21-2011, 10:50 AM   #602
DForehand99's Avatar
So far I have enjoyed my jl10e, we run them on a concrete oval with nastruck bodies. They are quick. But here lately I have had problems with my front ball diff. The front wheels are not pulling like they should, causing me to run at half speed. The bolt that goes through the ball diff broke. And know the new one has stripped out. I will try the ones from the website you have listed.
DForehand99 is offline   Reply With Quote
Old 03-21-2011, 11:56 AM   #603
MD
MD's Avatar
Trader Rating: 119 (100%+)
DForehand99 - Make sure you don't over tighten the diff. I have heard with other companies' diffs, some people will use a a little thread lock on the diff screw.
MD is offline   Reply With Quote
Old 03-22-2011, 05:26 AM   #604
Does anyone know what weight oil is in the shocks as it comes out of the box? Don
DLS II is offline   Reply With Quote
Old 03-22-2011, 06:52 AM   #605
MD
MD's Avatar
I don't know, but you can email or call Ofna. Just go to the "contact" page on their website.
Old 03-22-2011, 10:34 AM   #606
I will try thread lock also. I have just been getting it tight enough not to slip, but it seems to back out and strip. so hopefully the thread lock will prevent that.
Old 03-22-2011, 10:56 AM   #607
MD
MD's Avatar
When you say not slip, does it mean it doesn't slip at all?
Old 03-22-2011, 07:52 PM   #608
Sorry I'm a newbie, I maybe using the wrong words. On the other guys cars at the track you can push the car on the front wheels holding the backend up and the drive shaft turns. When doing the same on mine the drive shaft does not turn, theres no friction at all. When the front diff box is taken apart and I turn the front wheels the gear doesnt turn at all until you turn the back wheels. But if I push in on the cvd arms puttin pressure on the fron diff, and turn the front wheels it while lock and cause the gear to turn. Any help is appreciated.
Traxxas Slash 2WD
OFNA JL10E
Old 03-22-2011, 09:45 PM   #609
kael's Avatar
Review the manual for how to set the diff. You want it tight enough not to slip, but not too tight as you'll either burn it or break the diff screw.
Keep in mind most other folks are running their cars with a spool up front (a solid axle, no differential action).
Old 03-23-2011, 09:10 AM   #610
Should be 30wt front and rear.
A good starting point for circut racing is 60wt front 40wt rear.
D Starks is offline   Reply With Quote
Old 03-23-2011, 10:51 AM   #611
What does the spool eliminate the slippage allowing more power to the front? where are you guys finding the spools at?
Traxxas Slash 2WD
OFNA JL10E
Old 03-23-2011, 02:57 PM   #612
kael's Avatar
Some folks swear by the spool, feel it gives them more dig out of corners.
Me, I tend to swear at the spool. I simply drive better with a diff (on my TC5 that is). But then, I ain't no fast guy either.
For say VTA, diff is fine.
Old 03-23-2011, 08:49 PM   #613
I know some associated parts transfer over to the jl10, will a solid front axles from one of the TC's fit? if so which would be closer to fitting? Thanks
Traxxas Slash 2WD
OFNA JL10E
Old 03-24-2011, 09:21 AM   #614
The Spool from the 1/12 ABC car works in the JL10e.
Old 03-28-2011, 03:25 PM   #615
Send a message via Yahoo to e123
Is a 5.5 novak motor too much for this car? I read through the thread (all 41 pages!) and it seems everybody is running lower kv. I wont be racing the car, I just want something different to bash with. I'm curious about the 5.5 because I have one I'm not using right now. I have never run on-road before so sorry if its a dumb question.
e123 is offline   Reply With Quote
Picco .12 JL Red Dot & 30% heeltoedrver Nitro Off-Road 14 01-22-2009 07:22 PM
help me pick a engine LOW ET Onroad Nitro Engine Zone 19 12-27-2007 06:36 AM
