Old 09-22-2010, 10:11 PM   #541
macavant's Avatar
Trader Rating: 64 (100%+)
Originally Posted by S;
I am also pondering a EZRun Brushless system since you can get ESC and motor for less than $100.
-S
My bro-in-law has that setup on his TT01; for the $80 he paid - it's a good setup. It also came with a program card (I had to buy an additional castle link for my ESC). A 2S LiPo pack gives it great speed and a good amount of runtime.
likes the oldskool RC action...
F201☆F104WGP☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01.G6-01.SandScorcher☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 09-25-2010, 02:40 PM   #542
StPete40's Avatar
Trader Rating: 45 (100%+)
Default Battery Tray
[IMG][/IMG]
My solution for the stock battery tray. A piece of sheet plastic and miscellaneous hardware. Seems to work well and easy to swap batteries. Prototype is a little rough looking but its not a beauty queen to start with.
StPete40 is offline   Reply With Quote
Old 09-25-2010, 05:36 PM   #543
macavant's Avatar
Default another battery holder option
I purchased an AE battery box as previous posts suggested and added smaller velcro strips as hold downs. The plastic hold downs were tricky to fasten with thicker batteries (such as my 7-cell hump pack). The velcro straps make it way easier to replace batteries. I'm using 1 AE battery cup along with the stock battery holder, minus the plastic screw down tabs.
Ofna JL-10 E-img_8665.jpg   Ofna JL-10 E-img_8675.jpg   Ofna JL-10 E-img_8676.jpg   Ofna JL-10 E-img_8677.jpg   Ofna JL-10 E-img_8687.jpg
Old 09-28-2010, 04:35 PM   #544
StPete40's Avatar
Is there a sway bar set available for this car? If so, can someone pass along the part#?
Old 09-29-2010, 11:00 AM   #545
S
Looks like I could just remove the screw on plastic retaining bars for the stock battery holders and use velcro. The Associated would probably be lighter, but for the bargain hunter that I am, it looks like the velcro would work. Any reasons you know that it wouldn't?
-S
S is offline   Reply With Quote
Old 09-29-2010, 11:43 AM   #546
macavant's Avatar
-S
it should work - that's how I have the rear holder on my JL set up. The only thing about the stock holders, the weakpoint of the holder is where the hinged part is attached with the screw. It can break if the battery pack tends to shift forward and back.
velcro strips can be tucked under the stock holder to secure the pack down:
Old 09-30-2010, 05:34 PM   #547
MD
MD's Avatar
Trader Rating: 119 (100%+)
Is there anyone who uses the JL10E in VTA, if so what body fits?
MD is offline   Reply With Quote
Old 09-30-2010, 09:34 PM   #548
macavant's Avatar
If the HPI 200mm AAR Cuda is allowed in VTA; it fits fine. The body is 210mm @ the rear and 200mm up front. I managed to fit a +9 rear wheel and a +6 front wheel. I would suggest a 0 front and +6 rear for better clearance.
Old 09-30-2010, 10:46 PM   #549
MD
MD's Avatar
macavant - Thanks for the information. Your cuda looks great! My concern is that the rear vintage tires are 31MM. But. I'll check it out.
Old 09-30-2010, 11:30 PM   #550
macavant's Avatar
MD - if you're a GM fan - the Camaro body by HPI is also a 200mm front / 210mm rear. The DeTomaso Pantera is also the same way; 200/210.
Old 10-01-2010, 07:21 AM   #551
MD
MD's Avatar
Thanks.
Old 10-01-2010, 09:02 AM   #552
Md,
A word of caution. While these guys are answering your question correctly, some of the parts they are recommending are not USVTA legal. Make sure you know what is allowed before you order.
woodys3b is offline   Reply With Quote
Old 10-04-2010, 04:46 PM   #553
MD.
Trader Rating: 18 (100%+)
Does anyone know if an ABC genetic front one way will fit in the JL10e? I know they have some parts that look similar. Just wondering if the front diffs are the same or just similar looking.
http://www.abchobbyusa.com/frontonewayunit.aspx
MD. is offline   Reply With Quote
Old 10-04-2010, 04:56 PM   #554
mc4798's Avatar
macavant that is the the cleanest cuda I have ever seen. You ever drive it? I would put that in a glass case and just stare at it lol
mc4798 is offline   Reply With Quote
Old 10-04-2010, 08:31 PM   #555
macavant's Avatar
thanks. it's got "battle scars" now - I ran it @ nor-cal hobbies and had a few run-ins with barriers.
Picco .12 JL Red Dot & 30% heeltoedrver Nitro Off-Road 14 01-22-2009 07:22 PM
help me pick a engine LOW ET Onroad Nitro Engine Zone 19 12-27-2007 06:36 AM
