Old 02-11-2010, 08:52 PM   #376
CL
CL's Avatar
Trader Rating: 32 (100%+)
For parts, try www.nitrohouse.com. They are located next to OFNA and should have everything you need for that car.
CL is offline   Reply With Quote
Old 02-11-2010, 09:44 PM   #377
MD
MD's Avatar
Trader Rating: 119 (100%+)
I've used nitrohouse, which I think is basically Ofna.
MD is offline   Reply With Quote
Old 02-12-2010, 03:16 PM   #378
marvin2.5s's Avatar
if you lived in southern california, I'd go to west coast to get parts for the car.
TC5R
Ofna JL10E
Team Associated TC3 RTR / TC4 RTR / SC10
NISSAN/NISMO
MB racing technology
marvin2.5s is offline   Reply With Quote
Old 02-12-2010, 10:06 PM   #379
kael's Avatar
Originally Posted by kael View Post
I'm running my car in 17.5 rubber, indoor on carpet.
The rear end is spinning out, either corner entrance or exit, any advice?
Man, I've tried just about everything, car has massive oversteer. The only time I got anything remotely like a push was using dirty front tires with squeaky clean rears, worked okay for about 5 minutes before the rear started sliding again (for some reason our track leaves crap on the tires which we can clean off, but no traction compound is allowed).
Really frustrating.
\V/, Live Long and Prosper
kael is offline   Reply With Quote
Old 02-12-2010, 10:15 PM   #380
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Really frustrating.
Jack the Gripper is odorless and shouldn't affect the carpet. When i put it on, no residue was left on the tires.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 02-13-2010, 07:25 AM   #381
1555Racing's Avatar
Thumbs up nicely priced.....
https://www.rcplanet.com/ProductDeta...tCode=OFN34720
just picked mine up.
1555Racing is offline   Reply With Quote
Old 02-13-2010, 07:40 AM   #382
1555Racing's Avatar
Same address for corporate hq!! 7 Vanderbilt
Old 02-13-2010, 09:34 AM   #383
Yes, they are in the same building.
"Nitrohouse" is the retail sales outlet for Ofna but they also sell much more than just Ofna products. They are a great source of Mugen parts along with many other brands also.
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 02-13-2010, 09:25 PM   #384
Really frustrating.
Could you post your current set-up in more detail?
I know some are using the white springs up front. Can you use a sway bar on this car?
jeffb is offline   Reply With Quote
Old 02-13-2010, 10:10 PM   #385
kael's Avatar
Success! Was running too much, uh, too little, er....
Let's just say it had to do with droop and downstops and leave it at that.
Got the suspension working correctly and took the A main sportsman!
Old 02-15-2010, 01:01 AM   #386
Default Help with Under steering
Hi. I am a club racer and a bit of a noob with setup. I drive offroad nitro well enough, but I cant the onroad setup right. my track is:
Indoor
Painted with tennis court paint
sugared
short and tight
My JL-10 E car setup is:
Mostly Stock
0.5 to 1mm droop front
1 to 2mm droop back
ride height 4 to 5 mm
-1.5 degree camber (all-round)
1 degree toe-out
I have a hobby wing 12T with ESC.
Lipos
Foam tires (shore 35 back and 40 front)
34T pinion and stock spur (82T).
I changed the shocks to the 3 racing (the stock one are brittle and broke)
Not sure about oil (what ever come with 3 racing. I think 400wt)
stock JL-10E springs.
I check all setup parameters on a 3racing setup tool and I used a tweak station to balance.
I am struggling with on power under steer.
Any suggestions.
thanks
gadgets is offline   Reply With Quote
Old 02-15-2010, 09:48 AM   #387
Originally Posted by microcrazy24 View Post
ok first I really liked the body that they used on the show. is that good for racing? after seeing the show I went to my hobby shop to order and the guy at the counter never heard of the car. Anyway the guy in charge said he would order it so I should have it in a week. The car REALLY looked nice for the money.
I saw that rctvlive with the JL10 and I ordered the car but did not get that mustang body as I dont think it is good for racing. What is the best body for the rcgt races?
outrunner25 is offline   Reply With Quote
Old 02-15-2010, 11:26 AM   #388
Indoor
sugared
short and tight
Mostly Stock
1 to 2mm droop back
1 degree toe-out
Lipos
Any suggestions.
thanks
I would try a stiffer spring in back, add a little anti squat, less rear toe in, more traction compound on front tires. It could be one or a combination of all these things without driving the car it's hard to tell how far to go. Try one at a time until you get what you are looking for.
Old 02-15-2010, 12:33 PM   #389
marvin2.5s's Avatar
Thumbs up
well it mostly depends on how your car is setup. but a pretty stable body or bodies are the 350z and the MRS bodies as well as the supra if you can find one. hope this helps.
TC5R
Ofna JL10E
NISSAN/NISMO
Old 02-16-2010, 01:24 AM   #390
Thanks Jeff. I will try your suggestions and give feedback
Picco .12 JL Red Dot & 30% heeltoedrver Nitro Off-Road 14 01-22-2009 07:22 PM
help me pick a engine LOW ET Onroad Nitro Engine Zone 19 12-27-2007 06:36 AM
