Old 10-01-2009, 11:26 PM   #226
VenturaDC's Avatar
Trader Rating: 32 (100%+)
If anyone is interested we at the roadrunners will be having our 3rd annual Big Fat Turkey Race "The return of the turkey" oct 25th
there will be t-shirts,prizes, trophys and trophy girls and probably the taco guy again. We've had i think about 120 entries the last two years so we are expecting a good turnout.
If its like last year all entrants get a roadrunners t-shirt, Last years were way awesome if your a starwars geek like us roadrunners with starfighter touring cars and turkeys with lightsabers.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 10-02-2009, 09:11 AM   #227
skiptomylou6's Avatar
Originally Posted by D Starks View Post
Sorry can't make it to Speedtech this weekend.
Where will O.C. Circut be next weekend?
I'll hold it down for the team . Next week we'll be at La Mirada
skiptomylou6 is offline   Reply With Quote
Old 10-02-2009, 02:22 PM   #228
Good Luck Joe!
La Mirada sounds good to me.
D Starks is offline   Reply With Quote
Old 10-03-2009, 07:12 PM   #229
VenturaDC's Avatar
Anyone else having problems with the spur holder? Ive been thru 2 spurs in the last two days. thought it was my spurs till i toasted a PRS pro lite machined spur that spun dead true on my lathe, i noticed that it seems like the spur holder is kinda wonky. the shaft seems straight as i tried using double bearings in the diff housing to try to stabilize the shaft better and all new avid bearings and i cant see any movement on the shaft but can clearly see the spur holder rocking back and fourth as it spins.
It is tight and everything is shimmed to fit perfectly but the spur holder being "out of round" so to speak i cant get it to mesh well at all, i just tried to set it a little tight and bench run it for 30min at medium speed to "wear" the spur in but there is already one section on the spur that seems loose and might strip and the opposite side seems still a little tight.
is this part covered under any sort of warranty or should i buy another one to try?
Old 10-04-2009, 12:04 AM   #230
Thanks Dave! See you next Sunday!
VenturaDC- I have the same problem, however it seems like I just need to remember anytime I loosen the two motor screws I MUST RE-TIGHTEN them after ONE run. I went thru a spur at the RCGT Showdown, put a new one in, ran a qual, tightened it and it lasted the C-A Mains.
Old 10-04-2009, 12:24 AM   #231
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Ofna + electric sedan = brings back memories.
Awesome to see the JL-10 being popular. I remember getting started onroad racing with an OB4 International. Great car.
http://www.hongnor.com.tw/eng/pviewi...rea=48&cat=182
just thought id share my thoughts
Syber Serulean is offline   Reply With Quote
Old 10-04-2009, 07:16 PM   #232
revoTPR's Avatar
Joe-Sedan & Rev-RCGT race report for speedtech today..good running's for both JL's ...in Sedan 17.5,took home 2nd....in sports RCGT,TQ'd but caught up in some track maintenance last minute of the race, still took home 2nd.
da Return of da Comeback....tadadadannn :kembot:
// T.P.R. Team Pinoy Racing....oLskooL baby oLskooL!
Team JL-10 Ofna!! / ABC Genetic / Reppin OC Circuit!
Yokomo GT4
Express Sedan 4WD/Express Mini 4WD
revoTPR is offline   Reply With Quote
Old 10-04-2009, 09:20 PM   #233
VenturaDC's Avatar
Thanks! i did this today while running a few practice runs and had no spur failure, the holder is still lopsided but i guess as long as im not eating gears im good.
hey have a setup for speed tech? was thinking of trying to make some club races down there to break out of my camarillo bubble.
Old 10-05-2009, 10:37 AM   #234
Good Job Guys!
Old 10-05-2009, 10:52 AM   #235
VenturaDC's Avatar
Dave, Did the new narrow chassis replace the old one? i was looking on nitrohouse to order and i can only find part number OFN37133 and wasnt sure which chassis it was.
Old 10-05-2009, 12:05 PM   #236
Yup took the win in Stock. .
VenturaDC- Glad you didn't chew one up, I swear that motor mount acts like some aftermarket wheels on a car, always need to re-torque after a test drive . Anywho, as far as setup goes, I'd safely say your Camarillo set-up works there as long as the surface is prepped. Speedtech has the best natural traction due to it's concrete nature. Were you planning on running RCGT or Sedan? I prefer Sedan for my racing so i'd say get some RP30s for Speedtech and you'll be puttin' it DOWN!
Old 10-05-2009, 03:10 PM   #237
VenturaDC's Avatar
Thanks for the info joe.
I would love to come to speedtech to run sedan as we dont have a 17.5 sedan class here in cam besides novice and intermediate and changing back and fourth between 17.5 and 13.5 gets to be kind of a pain with all the programming changes so i would like to keep the 17.5 in the car since we have a big rcgt class here.
And thanks for the aftermarket rim analogy LOL having been a lead mechanic for a import tuner shop it made the most sense to me
Old 10-05-2009, 03:40 PM   #238
revoTPR's Avatar
saw the HOP-UPS for the JL-10...looks good Dave
Yokomo GT4
Old 10-05-2009, 03:43 PM   #239
revoTPR's Avatar
oops my bad Joe..i was thinking about your 2nd qualifier...stock sedan took 1st on the main.
i should have gotten it on video. next time ill bring my cam.
Yokomo GT4
Old 10-05-2009, 06:00 PM   #240
sweet! I was a tech for Honda and that was one of the things I hated about my effiency rating... always having to road test then come back to re-torque. . What shop did you work for? Exospeed?
Picco .12 JL Red Dot & 30% heeltoedrver Nitro Off-Road 14 01-22-2009 07:22 PM
help me pick a engine LOW ET Onroad Nitro Engine Zone 19 12-27-2007 06:36 AM
