Old 07-26-2009, 09:34 PM   #1
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
Default Steering Help
ok guys i striped out the plastic servo horn on my xray 008EU and when i replaced it i had to set the trim on my radio(spektrum DX3.0) right 15 points... didnt have to do this with that old servo horn.. the new servo horn is aluminum(all he had)
futaba S9551 servo..
Alex
hound_dogs_01 is offline   Reply With Quote
Old 07-26-2009, 09:37 PM   #2
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Alex
The splines are in a slight different position in the new arm.
Racecrafter is offline   Reply With Quote
Old 07-26-2009, 09:40 PM   #3
so should i move the arm or keep it trimed out on the radio?
Alex
Old 07-26-2009, 09:52 PM   #4
I would re center the servo to 0 first, then try that. maybe set a bit to the left if you need so much to the right.
xevious613 is offline   Reply With Quote
Old 07-26-2009, 10:24 PM   #5
someone told me you have to set the servo horn like 12 degrees to the front of the car for it to work right
Alex
Old 07-27-2009, 01:09 AM   #6
Alex
You have to get all angles in the steering to be 90 degrees. So you have to adjust the lenght of the turnbuckles in a way that you get 90 degrees everywhere. After that you should put up the horn on the servo. And if it still needs a trim it's only 1 or 2 clicks.
With this 90 degree angles the angles of the servohorn is the least important, but the other ones are.
Rick Thomson is offline   Reply With Quote
Old 07-27-2009, 01:11 AM   #7
ok thanks for the tip!!!
Alex
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 11:31 AM
Kyosho V-ONE RRR Evo boy2rc Nitro On-Road 3234 08-07-2014 12:43 AM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 08:36 AM
Back into R/C! Just bought a Losi Mini-T! Need help! Jongrill Micro and Mini Scales 10 05-18-2009 07:15 PM
Trasmitter Set up for new Driver imjonah Electric On-Road 16 01-31-2004 09:44 PM
