Ko Radios?
Old 01-16-2004, 07:09 PM
Trader Rating: 19 (100%+)
Default Ko Radios?
I was looking to buy a Mars EX 1, R or Helios, but I am trying to figure out which one will work with the Novak XXL receivers on 75mhz band. Can anyone tell me which one does or what receivers each one works with? Any information would be helpful. THANKS!
429racer is offline
Old 01-16-2004, 07:14 PM
trueracefan's Avatar
Novak receivers that are specified KO will work although the Hrs (High response speed) will not work with novak receivers.
I just got a helios and love it
trueracefan is offline
Old 01-16-2004, 07:21 PM
The ones I have for my M8 are Fm Futaba receivers. I was reading somewhere that some Novak receivers will work with KO radios, but you have to hit some switch. I don't know if that just applies to the KO Novak XXL receivers or all.
429racer is offline
Old 01-16-2004, 07:28 PM
Kevin K's Avatar
Trader Rating: 32 (100%+)
The Novak XXL receiver for KO will work with the HRS of the Helios. You do not need to flip the switch to turn it off when using the XXL. It works fine.....a KO driver checked with KO and they said it will work with out any problem.
Kevin K is offline
Old 01-17-2004, 02:15 PM
Impreza's Avatar
The XXL recievers will not work with the Mars R. But they work fine with the older Mars EX-1.
Impreza is offline
Old 01-17-2004, 07:03 PM
NR
NR's Avatar
Trader Rating: 52 (100%+)
Default What will??
What aftermarket recievers will work with the Mars R??
Any help would be appreciated.
Regards
NR is offline
Old 01-18-2004, 04:32 AM
antoniop's Avatar
They do work in normal PPM mode. Not in HRS mode.
The KO crystals are a direct fit. KO Rx uses the same internal freq as Novak, Sanwa/Airtronics, Multiples, Nosram, LRP, Mtroniks, and that is 455 Khz.
antoniop is offline
Old 01-18-2004, 03:49 PM
antoniop's Avatar
Since this is a KO thread and someone may have the same issue I had today, here goes:
I configured my EX10 to work in ARS mode. Digital servo, 302F rx and the little switch behind the Tx module set to HRS.
The ESC is a Nosram Dominator Evolution
On the first 2 runs of the day the motor felt "soft". Not soft and fast, but clearly lazy. I attributed this to the motor and changed it to the motor I knew had lots of punch.
Again very lazy acceleration no matter what ratio I used. Even with short ratios the thing would accelerate slowly.
I checked the calibration of the ESC, program, battery charge, state of the motor and anything you may think of.
Then all of a sudden I remembered that the last time I practiced the radio was in normal PPM mode.
I switched HRS off and VOILA!!!
The car was now flying around the track with the fastest guys.
Not sure what this is coz the manual states clearly that ARS and HRS has no influence on the ESC.
However this small difference means more than one second per lap....
Go figure. Probably someone has a good explanation for this.
antoniop is offline
