Old 09-17-2009, 03:46 PM   #76
dawgmeat's Avatar
what is the max discharge rate for 5200 mah 50c
dawgmeat is offline   Reply With Quote
Old 09-17-2009, 04:10 PM   #77
Trader Rating: 16 (94%+)
5200/100 = 5.2 x 50c = 260 Amps
kn7671 is offline   Reply With Quote
Old 09-17-2009, 04:29 PM   #78
dawgmeat's Avatar
so constant 30 amp is ok
Old 10-25-2009, 12:16 PM   #79
irgo's Avatar
that would be depend what motor and esc you are wearing
But with constant 30Amp draw that would mean your batt will stay cool
but you might forgot about your Burst ? right ?
Quark Force
irgo is offline   Reply With Quote
Old 10-25-2009, 12:33 PM   #80
irgo's Avatar
Default Balancing one hole 2S
Originally Posted by Team_Elli View Post
Since this is the only SMC thread i found, how do i setup the balancing conector on these batteries since it's only one hole for the the balancing plug on the 4700mah Reinhard editon? I now it's stupid question, but i like the info before i buy something so i can do it correct first time
Edit: can i use this one by the way? http://www.nexusracing.com/product_i...oducts_id=2561 or http://www.nexusracing.com/product_i...oducts_id=2426 just found it
The one hole at the center between potential + and - is one of the wire to include when balancing.
So balancing would Required 3 Wire minimum for Balancing this battery,
the + - and center hole.
the center hole is a bridge between the 1st and 2nd cell
which mean it is + and - wire for both Cells
it's like this
[Cell1]-------[cell2]
l-------ll-------l
-----center
------holes
you must have the connector for balancing that had 3 wires for it.
for the (+) (-+) (-).
Hope this will help you
Quark Force
