Old 08-20-2009, 09:44 AM   #61
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Originally Posted by CHARLIE WANG View Post
Check this on Google: LiPo Battery Shootout
Big Squid RC
Im sorry but that was the stupidest so called test I've ever seen.
Comparing a 3600 to an 8000. apples and oranges man
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 08-23-2009, 05:03 PM   #62
Since this is the only SMC thread i found, how do i setup the balancing conector on these batteries since it's only one hole for the the balancing plug on the 4700mah Reinhard editon? I now it's stupid question, but i like the info before i buy something so i can do it correct first time
Edit: can i use this one by the way? http://www.nexusracing.com/product_i...oducts_id=2561 or http://www.nexusracing.com/product_i...oducts_id=2426 just found it
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 08-23-2009, 05:25 PM   #63
CraigM's Avatar
Trader Rating: 34 (100%+)
I'm also sorry to hijack, but I've got two of the above packs and plugged one in backwards yesterday (ESC was off) and something shorted inside and now the pack doesn't work. Is it gone or can this be fixed?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-23-2009, 05:38 PM   #64
I am no battery expert, but i think you might have shorted the circuit board inside the battery? what kind of SMC battery is it?
*Sanwa M12*Hitec*
Old 08-23-2009, 06:01 PM   #65
CraigM's Avatar
The Rhenard edition 4700 40C. Yeah I'm sure its something on the PCB, it has that telltale burnt electronics smell. I'm just wondering if its repairable and if so where can I get it repaired
Old 08-23-2009, 07:02 PM   #66
fly_wheel's Avatar
it might be the banana plug has been desoldered or sort... just open the case n resolder them... the PCB has no other things except some solder n plugs... easy fix... heat the case with a hair dryer n pull the case apart slowly...
There are more in racing than winning.
fly_wheel is offline   Reply With Quote
Old 08-24-2009, 08:25 AM   #67
the top one is for the Check Point balancer..
Looks like the other is for the ThunderPower.
Old 08-26-2009, 04:29 AM   #68
1bigshane's Avatar
Trader Rating: 18 (100%+)
do u guys think my novak gtb with a 17.5 motor can take a 50c rating? and for how long before meltdown? i want to run the smc 50c at the iic in vegas!
1bigshane is offline   Reply With Quote
Old 08-26-2009, 05:27 AM   #69
Born2Run's Avatar
Why it should meltdown?
Whatever
Born2Run is offline   Reply With Quote
Old 08-26-2009, 07:25 AM   #70
SPC
Registered User
Originally Posted by hana166 View Post
Who does the 50C for 129 dollars?
We do. spcracing.com
SPC is offline   Reply With Quote
Old 08-26-2009, 10:09 AM   #71
Yes, you can't think it like the battery "gives" the amount of amps. It's the motor "taking" what it needs. You will be fine. Your motor won't touch the amount of amps this battery can provide
montyjcm is offline   Reply With Quote
Old 08-26-2009, 03:48 PM   #72
1bigshane's Avatar
thanks guys for the info, i will be buying 2 of them,unless smc wants to provide me with them.lol
Old 08-30-2009, 06:00 AM   #73
But can i use one of those for the Smc pack?
*Sanwa M12*Hitec*
Old 08-30-2009, 11:14 PM   #74
1bigshane's Avatar
i just orderd the smc 50c from rc-toro and they sent me this: The comments for your order are
The SMC lipo I have in stock seem to puff a little. I would return all of them
to SMC. Would you like to wait for the new replacement from SMC? Or refund?
Please let me know.\ whats the deal
Old 09-06-2009, 08:59 AM   #75
yokemad's Avatar
what's the latest for these ?
Also some online shops has put SMC 4700 40C on sale and the rest says their stock is the second batch with improved pcb connection board
yokemad is offline   Reply With Quote
