Old 07-25-2009, 12:45 PM   #1
mac853's Avatar
Questions?? Powering motor fan with LIPO RX battery!
As the title said, if is worthy with advantage or not if i put my motor fan powered independently with a LIPO RX batteries instead from RX itself?
Like that MM RX batteries with switch and hi-low protectors, if has enough power to do that?
Since our rule book didn't mention that not allowed to do it, it is possible or not to do it?
Best regards
mac853 is offline   Reply With Quote
Old 07-25-2009, 01:44 PM   #2
JKL1031's Avatar
sub
JKL1031 is offline   Reply With Quote
Old 07-25-2009, 03:37 PM   #3
Trader Rating: 38 (100%+)
Best regards
Why not directly off your main battery? That is what I most often seen done. solder it directly to the +/- on the ESC
or8ital is offline   Reply With Quote
Old 07-25-2009, 07:11 PM   #4
cyanyde's Avatar
If you are under weight and wanna squeeze every ounce of juice from your batt then go ahead. It may make a difference in 8 minute runs.
cyanyde is offline   Reply With Quote
Old 07-25-2009, 11:14 PM   #5
mac853's Avatar
Questions??
Off course is still underweight and i am also racing in 8mins but i just want if really worthy to do that.
And want to know if this kind of RX batteries don't have balance connection could charge at LIPO chargers anyway without problems?
Old 07-25-2009, 11:40 PM   #6
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
if you do it this way remember to alwasy disconect your lipo because even though the switch is off the fan is still running if the battery is plugged in...
hate to see you kill a lipo this way...
Alex
hound_dogs_01 is offline   Reply With Quote
Old 07-26-2009, 03:57 AM   #7
mac853's Avatar
Questions??
Alex
I wonder to use MM LIPO RX battery(picture below).
What do you guys think about it?
Old 07-26-2009, 04:02 AM   #8
why do you want to add all that to your car? its much simpler to solder two connections on the ESC... youll never see the difference in run time what power that little fan pulls off the esc's lipo....
Alex
Old 07-26-2009, 07:43 AM   #9
heretic's Avatar
You did not tell what class you run ? In 1/12th nobody uses fans so...
2s lipo ?
4,8 nimh ?
3,7 lipo ?
heretic is offline   Reply With Quote
Old 07-26-2009, 10:20 AM   #10
dameetz's Avatar
Talking about fans....any recommendation which one is good out there? I ve had 3racing before but that was crap, the fan spins but you cannot feel the blowing air. I m looking for 30x30 size for my motor heat sink and 25x25 for my ESC. At the moment i m using a No Brand fans which are rated at 0.16a, looking for a more powerful one....BTW I m running mod touring in a hot tropical climate country so I guess having a good fan is a must.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 07-26-2009, 10:37 AM   #11
mac853's Avatar
Exclamation
2s lipo ?
4,8 nimh ?
3,7 lipo ?
Well?
I still only running in TC.
OK, OK!
Anyway since i said running on 7.4 LIPO, anybody will say me is totally ridiculous to inventing an useless thing on a useless situation!
Very well, i guess we have to forget this thread!
About you are looking for better fans, i just say many ones on the market are better than this weak 3racing fan.
Anyway, how about YR fan, i don't know if is really good, in case i never seen before anyone around me used, but at least take a look on it with your eyes.
Old 07-26-2009, 10:53 AM   #12
Senna Racing's Avatar
if your after a fan you cant go past this one
it dropped my motor temp by 20c from the 3racing one
http://www.amainhobbies.com/product_...an-w-Heat-Sink
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 07-26-2009, 11:40 AM   #13
see if you can find one of these... theyre bad ass good luck.... i searched for 3 hours and found ONE of these fans on the whole world wide web....
http://www.nexusracing.com/product_i...oducts_id=1341
Alex
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
