Old 07-24-2009, 05:00 PM   #1
Trader Rating: 62 (100%+)
Default Duo vs. Duo 2
So I'm in the market for a 13.5 motor and at our track the Duo motors seem to be the fastest. Question is which one do I get? Have any of you guys that have been running the Duo done any testing with the Duo 2?
patrick is offline   Reply With Quote
Old 07-24-2009, 06:47 PM   #2
Send a message via AIM to Twotan
I would like to know also. I am looking to buy one of these 17.5 motors.
www.monarch-wheels.com
Magic Film's automotive car protection. Deals on the first 15 people.
Twotan is offline   Reply With Quote
Old 07-24-2009, 08:12 PM   #3
JimmyMac's Avatar
The Duo 2 will allow finer timing adjustment on the motor.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-24-2009, 08:17 PM   #4
thisguy2849's Avatar
The duo 2 has timing adjustments from 10 to 30 degrees with the ability of doing it with the motor in the car by loosening 3 screws in the end bell nd turning the end cap. You also can change the timing in small steps instead of 10 degrees at a time like the original duo. Ive been running the new motor for a couple weeks now and they are very fast. Be sure to go down a few teeth when u put it in so you dont burn it up lol. Always good to be under geared and save a motor than be over geared and burn it up.
thisguy2849 is offline   Reply With Quote
Old 07-24-2009, 10:34 PM   #5
Is the only difference the endbell timing setup? Or does the motor have different properties as well? Does anyone have the Kv readings for both motors as this is usually the best indicator for the type of motor (rpm vs torque)
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-24-2009, 11:09 PM   #6
The motors are very similiar. By running them on a phantom dyno the duo 2 is putting up a little bit better numbers from what ive seen. The new duo has more power coming out of the turns when ive been racing them and if geared right it cant be touched down a straight
Old 07-27-2009, 02:05 PM   #7
Ok that's good info, thanks.
Old 07-27-2009, 02:09 PM   #8
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Dont know for sure... but from what i have heard, the only difference is in how the timing is adjusted. The rest of the motor shoudl be the same.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-27-2009, 03:45 PM   #9
Trader Rating: 28 (100%+)
rotor is different too.Stronger.
Team I'm Over It
racenut123 is offline   Reply With Quote
eXpress Motorsports Jon Williams Team and Company Discussions 18296 11-16-2016 03:17 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Thunder Power 5000mAh 1S Lipo kyle478 Electric On-Road 48 07-26-2009 07:55 AM
May give up Baja 5T and go Flux. Questions abound Freezebyte Electric Off-Road 10 04-18-2009 06:31 PM
Hyperion 606i or 610i Duo Charger Question? wrxnfx Radio and Electronics 8 10-20-2008 05:20 PM
