Old 07-24-2009, 01:00 PM   #1
Default Wheel Offset... is this right???
Was looking for 1/10 scale touring car wheels for a 200mm body on a T2 007 and came across RC Planet's website but the description of various offsets does not make any sense! They say that a 9mm offset will fit wider than a 3mm! In the real car world, it is the other way.
Am I missing something...
Read below: These wheels are available in 3mm, 6mm and 9mm offsets. 3mm offset gives a slightly wider stance to help fill out the wheelwells. Owners of 190mm electric cars can use our 6mm offset wheels if they want to use 200mm bodies. Throw on a pair of 9mm offset wheels for a super wide look.
t4tx is offline   Reply With Quote
Old 07-24-2009, 01:04 PM   #2
rccardr's Avatar
Your conclusion os correct. Big cars and R/C cars are exactly opposite in how they measure offset. A 3mm offset R/C wheel will have a wider track than a zero offset wheel.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 07-24-2009, 01:18 PM   #3
Thank you. So, if I have a T2 007 and I want the fitment to be "flush" with the fenders, what are the possible offset/body width combinations that I can run?
I.e. 200mm body with 9mm offset or 190mm body with 6mm offset, etc???
Old 07-24-2009, 02:31 PM   #4
heretic's Avatar
190 mm body with 0 mm offset
The xray is supposed to be 190 mm wide. You should choose the body according to your chassis, not try to adjust your car to a body.
My 2 cents.
BTW excellent choice, the 007 is a great car.
heretic is offline   Reply With Quote
Old 07-24-2009, 04:00 PM   #5
andyh's Avatar
Default ...
With a standard 190 mm Electric TC chassis X-Ray T2, Cyclone etc... you will need to run either a 3mm front with 6mm rear offset to be flush with most 200mm bodies. Some "wider fender/body kit" 200mm bodies require a wider setup (ie. 9mm rear) Although most of the time the 3mm/6mm combination works best.
This photo shows a 6/9 combo, looks good for photos but for running, 3/6 would be better (to prevent fender rub)
The below 200mm MR-S is on a 190mm spec Cyclone TC with a 3mm/6mm combo.
andyh is offline   Reply With Quote
Old 07-24-2009, 05:04 PM   #6
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Lol, now we are going flush with R/C cars?
IIGQ4U is offline   Reply With Quote
Old 07-24-2009, 08:00 PM   #7
Just roll the fenders... lol
Thanks for the feedback guys... I guess flush doesn't work too well for r/c but at least I now have an idea about proper fitment. Thanks.
Old 07-24-2009, 08:24 PM   #8
IIGQ4U's Avatar
Here's one of my cars
Old 07-25-2009, 12:24 AM   #9
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
Hell Yeah we are LOL =D
We been doing Flush in RC drifting for years now LOL
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 07-25-2009, 10:52 PM   #10
NEVADAGARY's Avatar
Here's my electric 4TEC with a 200mm body on the 190mm track. The picture below is with a set of Tamiya 4mm offset wheels and Duratrax slicks. Not a hell of a lot of difference.
4mm o/s
Gary D.
NEVADAGARY is offline   Reply With Quote
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 08:59 PM
Jaco Foam Tires PaulP Electric On-Road 32 11-07-2002 10:16 AM
