Old 07-24-2009, 12:42 PM   #1
Default Cooling Fan w/ DX3s in AUX?
Hi I just got a cooling fan for my mini e-revo esc that I planned on using with my DX3s in the AUX channel on the SR3300T receiver. I thought I would be able to turn it on and off with the AUX switch. Is this possible?
lucasfinley is offline   Reply With Quote
Old 07-24-2009, 12:52 PM   #2
I don't see why not. If worst comes to worst it will just run all the time, which isn't so bad either.
Jay
~ Jason Kennedy ~
~ Sweep Racing Tires ~
~ TQ Wire~Wire~
pyro18t is offline   Reply With Quote
Old 07-24-2009, 01:15 PM   #3
I was just wondering if anyone knew how to do it because I can't figure it out. The manual only talks about duel steering and what not using the AUX.
Old 07-24-2009, 01:21 PM   #4
i just checked on mine with my transponder and it doesn't turn off
i dont know how it works though
sidecarphil1 is offline   Reply With Quote
Old 07-24-2009, 01:29 PM   #5
Johnny Wishbone's Avatar
It won't work. You're just using the 2 common lines for the power to the fans (+ and -) you would have to incorporate the signal side of the rxr to activate your fans, but since its a pulse signal you would need a relay to make it work.
Old 07-24-2009, 01:34 PM   #6
yeah its just the negative and positive lines. thanks for the help!!!
