Old 07-22-2009, 06:52 AM   #1
Default New to electric - Question
Hi, i just got a old schumacher i had laying around running..
problem is, the motor is getting really hot..
im running a 30pinion/92spur (3.07).. am i overgearing it?
the other spur i have is a 86t which would make it 2.87,
should i put the other spur on?
running 540 motor by the way.
LiL_JaSoN is offline   Reply With Quote
Old 07-22-2009, 07:00 AM   #2
Stusdal's Avatar
The 86 spur will just make it hotter.
What motor is it and wich schumacher model?
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 07-22-2009, 07:02 AM   #3
schumacher 1..
just a car i had laying around..
running a crappy old 480.. but i have a johnstone 540 laying around.. i might put that on instead
Old 07-22-2009, 07:04 AM   #4
pejota's Avatar
Did you check all your bearings to see if they are bound up or dirty?
If it was just laying around make sure the drivetrain is loose and spins freely.
pejota is offline   Reply With Quote
Old 07-22-2009, 07:10 AM   #5
when the motor is not meshed, it can roll freely for miles
but when i mesh it no matter how loose, it doesnt roll as good? normal?
Old 07-22-2009, 07:14 AM   #6
pejota's Avatar
Lube the bearings/bushings in the motor.
If that doesn't work, try another motor.
As for the 540 gearing, try the schumacher website and look for stock or 27 turn gearing options. They will probably give you an FDR suggestion. That's Final Drive Ratio. Then go to gearchart.com to punch in your spur/pinion and car model to figure out your options.
Old 07-22-2009, 09:14 AM   #7
ok i cleaned the rear diff as it was dirty and tight.
read through the manual..
and it says if running a 20t pully
max tooth sum - 131
min tooth sum - 108
is that just the spur(92t)+pinion(30t)? or am i adding the 20t pully aswell..
Old 07-22-2009, 09:22 AM   #8
Old 07-22-2009, 09:26 AM   #9
Mooshu Beef's Avatar
This is normal because the motor provides resistance on the drive line. It's good the car rolls for miles if no motor is installed because this means your driveline is relatively smooth.
Do you have a temp gun? Sometimes motors just get "hot" to touch, but are well below the max recommended temperature.
In general, if a motor is too hot, get a bigger spur and/or a smaller pinion.
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 07-22-2009, 09:34 AM   #10
DARKSIDE's Avatar
perfect car for VTA..love old school
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is online now   Reply With Quote
Old 07-22-2009, 09:54 PM   #11
thanks, ill see how the car runs..
i had it laying around in the garage, and it looked like i still can get parts for it.. so i decided to get it running.
i got a temp gun, i guess ill be aiming between 38-66c
Although not always true, a rule of thumb is:
Hot motor, cool controller, cool batteries = undergeared
Cool motor, hot controller, hot batteries = overgeared
hot motor, hot ESC, and hot batteries = way overgeared
Warm motor, warm controller, warm batteries = happy components
Hot, warm, and cool vary as well, so here's another general rule:
Hot for a motor = generally over 160F (71C)
Hot for a controller = generally over 150F (66C)(or "thermal" range for the controller)
Hot for batteries = generally over 150F (66C) for nimh, 130F (54C) for lipo
Warm for a motor = generally 100F (38C) through 150F (66C)
Warm for a controller = generally 100F (38C) through 130F (54C)
Warm for batteries = generally 100F (38C) through 130F (54C) for nimh, ambient temp through 120F (49C) for lipo
Cool for all components = generally ambient temp and up to 10 degrees F (5.6C) more
The reasons the above are not always true are numerous, but may include:
Sticky drivetrain - will put un-necessary strain on electronics whether geared correctly or not.
Poor quality batteries - batteries will heat up regardless of gearing.
Wrong motor for the application - will put un-necessary strain on electronics whether geared correctly or not.
Wrong controller for the application - will put un-necessary strain on electronics whether geared correctly or not.
Traxxas Revo futureal Monster Trucks 3275 11-23-2017 07:38 AM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
West Coast R/C Raceway & Hobby Garage In So. Cali! DannyS California Racing 14045 01-19-2014 09:33 PM
New to electric racing...need help!!! Raptorrickg Electric On-Road 6 08-12-2009 06:50 PM
2009 Beat the Heat thread JLock MSRA (Memphis, TN) 496 07-16-2009 04:32 AM
