Old 07-21-2009, 03:58 PM   #1
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Default 7.4v 2S Lipo charging error message, help please
Guys,
After some racing, im trying to charge my 7.4v 2S 5.200 lipo and during "battery check" on my charger, the error message of "over voltage" appears and does not let me to charge, discharge or balance my batt, what could be ?
thanks a lot,
Pat
Tabushi is offline   Reply With Quote
Old 07-21-2009, 06:55 PM   #2
Thirtybird's Avatar
Make sure your charger is on the correct profile for 2s LiPo. It may be set to 1s or some other chemistry type. If the voltage is less than 8.4V, then it is not over voltage for 2s LiPo, and there must be a setting problem on the charger
Racing a Kawada SV-10 in 2010
http://omgitsakawada.blogspot.com/
The VTA Photon! (Inactive - back to the Kawada!)
http://vtaphoton.blogspot.com/
Thirtybird is offline   Reply With Quote
Old 07-21-2009, 11:25 PM   #3
This type of message can occur on a balancing charger if just one of the cells is over voltage. Check both cells seperately.
Shawn.
Shawn68z is offline   Reply With Quote
Old 07-21-2009, 11:27 PM   #4
Tabushi's Avatar
Shawn.
Thanks Shawn, it seems thats the problem, but how can i solve this ?, its impossible to do ANY action on the charger not even discharge because when the charger CHECKS the battery throw out the error message, any help ?
thanks,
Pat
Old 07-22-2009, 12:53 AM   #5
razzor's Avatar
thanks,
Pat
You can measure each cells voltage through the balance plug.
Then run the battery in the car if a cell is over 4.2v.
Once done put it on a balancer to equalise before balance charging.
What charger are you using ?
Some chargers wont charge if there is a voltage difference of .4v or more untill the battery is equalised.
Check if your charger balancers on its own and then leave it to balance for a few hours.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-23-2009, 08:00 PM   #6
Tabushi's Avatar
Thanks a lot guys, problem solved.
I connected an external (stand alone) balancer for couple hours and then back to my charger/balancer and it charged the battery perfectly.
This happened after charging the battery couple times WITHOUT balancer, only direct charging ...
thanks for your help,
Pato Concha
Southamerica
Old 07-24-2009, 12:31 AM   #7
razzor's Avatar
you can direct charge but every now and then balance the pack.
Only balance when pack is full, or balance charge after every 10 charges.
Casterracing ZX1.5R
