Old 08-20-2009, 03:47 PM   #106
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Novak guys,
Just a doubt, if i want to go racing with novak, on 6 nimh cells or 7.4v 2s lipos on 1/10 touring and 8.5 to 13.5 motors, which its my BEST bet on speedos, GTB or HAVOK PRO ?, and why ?
thanks !
Pato Concha
Southamerica
Tabushi is offline   Reply With Quote
Old 08-20-2009, 03:54 PM   #107
The Evicerator
Default Havoc Pro Height
The Havoc Pro's height is 0.895" or 22.75 mm.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 08-20-2009, 05:26 PM   #108
Company Representative
Originally Posted by pakk View Post
Hmm maybe I don't understand you. Will the motors out of the box be capable of 0 timing or will I need additional parts?
All Ballistic can be adjusted to 0 timing.
NovakTwo is offline   Reply With Quote
Old 08-20-2009, 05:27 PM   #109
Originally Posted by Armaan View Post
Novak Havoc Pro? Is this Novak's answer to the Tekin RS and Tekin RS Pro?
No.
Old 08-20-2009, 05:28 PM   #110
Originally Posted by hippie View Post
That sounds great . Any idea when this might be avalible ?.
I will post updates when the Havoc cooling plate is available.
Old 08-20-2009, 05:36 PM   #111
The Havoc Pro is cheaper, has the same performance, includes additional & more intuitive on-board programming options. And, it looks cooler...
Right now, it would be the better choice.
Originally Posted by Tabushi View Post
Novak guys,
thanks !
Pato Concha
Southamerica
Old 08-20-2009, 06:07 PM   #112
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
The Havoc Pro does look cool!!!!!! Cheaper isn't a bad thing either.
ST Racing Concepts (STRC)
wyd is online now   Reply With Quote
Old 08-20-2009, 06:21 PM   #113
Armaan's Avatar
Trader Rating: 49 (100%+)
Hmmm, I'm guessing Novak has something up their sleeve to compete with the RS Pro...possibly the GTB Pro?
I remember the old Novak ESC progression...I ended up buying a bunch of their ESC's:
Novak T4
Novak T1x
Novak 410-M1c
Novak 410-MXc
Novak 410-M5
Novak 410-HPC
Now there's just Havok and GTB.
Armaan is offline   Reply With Quote
Old 08-20-2009, 06:42 PM   #114
.....Hmmm,
The Havoc, GTB and these eight others...
Novak Brushless Speed Controls
Old 08-20-2009, 07:13 PM   #115
Trader Rating: 20 (100%+)
THANK YOU
hippie is offline   Reply With Quote
Old 08-20-2009, 07:20 PM   #116
wyd
Tech Legend
wyd's Avatar
The price on the Havoc Pro that I just saw is excellent.
Old 08-20-2009, 08:05 PM   #117
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
What size are the bearings in the Ballistic motors?
mrrcguy is offline   Reply With Quote
Old 08-20-2009, 10:40 PM   #118
EricF's Avatar
Thanks Steve.
E
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 08-21-2009, 02:14 PM   #119
Default Ballistic Motor Timing, Part Two
Ballistic Motor Timing Information Update (Preliminary)
In an effort to answer a number of questions relating to motor timing we have compiled some information to help you better understand static motor timing and its effects with our Ballistic Series of motors.
“How many Degrees of Timing does my Ballistic Motor have?”
Our Ballistic motors come with their timing calibrated and set from the factory. Using custom built and calibrated electronic equipment we set each and every motor to 30 degrees of timing. After Calibration the timing label is added and this set timing corresponds to the “N” on the timing label on the side
Each line on the label denotes a 5 degree change, so the timing available on the motor the label corresponds as follows:
-3 -2 -1 N +1 +2 +3
15 20 25 30 35 40 45
N = 30 (rows do not line up correctly)
SPECIAL NOTE: The timing we are describing is the ACTUAL ELECTRICAL TIMING in the motor, not just some arbitrarily reference made from a point on the outside of the motor like many of our competitors' motors. This makes comparing timing settings between different brands of motors difficult without the proper equipment.
“What Does Timing Adjustment do?”
We set our timing at an optimized point for most general applications. Adjusting the timing should only be done in small increments and with great care to observe the changes in system performance and temperatures.
WE RECOMMEND THAT YOUR SYSTEM’S TEMPERATURE NEVER EXCEED 160 DEGREES FARENHEIGHT.
When adjusting the timing, we recommend adjusting the timing, at most, 1 notch, or 5 degrees at a time.
When you turn the timing up to a more positive number (from N to +1) your motor will produce more no-load RPM and generally suffer a slight reduction in torque. To combat excessive heating brought about the loss of torque we recommend gearing down 1 tooth on the pinion for each notch (5 degree increment).
When turning the timing down, to a more negative number (from N to -1) your motor will produce less no-load RPM and generally experience an increase in torque. To combat a loss of top end speed brought about by the loss of RPM we recommend gearing up 1 tooth on the pinion for each notch (5 degree increment).
Ballistic Timing Questions, Part 2
“How do I set my Ballistic to zero degrees of timing?”
The factory timing for the Ballistic is 30 degrees of timing and corresponds to the N on the timing label on the back of the motor.
We do not recommend running zero degrees of timing for most applications and would recommend running at least 5 degrees of timing to ensure proper operation of the motor.
NOTE: When running your timing lower than the pre-set factory 30 degrees your reversing function of your Novak ESC may not work properly as it accounts for this 30 degrees of timing in its commutation sequence.
To adjust the motor to this lower 5 degree timing setting:
1. Loosen the three 1.5 mm hex head screws on the back timing cap of the motor
2. Turn the end-cap clockwise until the stationary notch on the endbell lines up with the edge of the label as demonstrated in the picture below:
[Photos to be added when posted to Novak website]
3. Re-tighten the three 1.5 mm hex head screws in a circular pattern to ensure that they are all tightened evenly.
Old 08-22-2009, 01:59 PM   #120
Is the Novak 4 cell GTB & this module compatable to use on 1s lipo in my WGT car ?. Thank's
http://teamnovak.com/products/smart_boost/index.html
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 11:58 PM
