Old 12-25-2009, 05:48 AM   #271
Originally Posted by kriiiss View Post
hey guys why is the sensor cable so hard to remove from the motor?
I tried pulling mine out today and it wouldnt budge
I wasnt yanking it or stretching it
I was jus gently pulling it out then all of a sudden the cables rip off the plug
I lifted up the cover around the sensor and used a flathead to pry out the sensor plug and got it out....but are there any other ways to remove the sensor cable from the motor?
thanks......merry xmas everyone!
I found this problem on mine, just unscrew the 3 timing ring screws a little, this will allow the sensor cable to be pulled out with ease
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 12-25-2009, 07:00 AM   #272
Trader Rating: 38 (100%+)
How would I gear a Novak Ballistic 17.5 relative to a Duo2? Do I need more or less gear and approx how many teeth?
or8ital is offline   Reply With Quote
Old 12-25-2009, 07:16 AM   #273
lowcel's Avatar
Trader Rating: 80 (100%+)
Originally Posted by Jochim_18 View Post
The shaft on 13mm Rotor have a mark.
Thanks, and thanks for the pm. Would I be able to see this without taking the motor apart or do I need to take it apart to see it? I purchased a motor that is supposed to have a 13mm rotor but I don't see any marks or notches.
Team Whopperjawed Racing
This hobby is going to $5 me to death.
lowcel is offline   Reply With Quote
Old 12-25-2009, 08:35 AM   #274
Company Representative
Check out the small photo here; you may need a standard 12.3mm rotor for comparison:
Novak 13mm Tuning Rotor
The Ballistic was designed so that the sensor harness could be removed (only) by loosening the screws. In some motors the plug-in sensor harness will come out due to a hard jolt; the Ballistic w/silicon seal was designed specifially to prevent this.
NovakTwo is offline   Reply With Quote
Old 12-25-2009, 08:48 AM   #275
Jochim_18's Avatar
Start at 4.6 FDR with 35 degree of timing. We run this motor with Mamba Max Pro ESC it's a rocket on the track.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 12-25-2009, 09:14 AM   #276
Stock is 30 degrees of timing right? So does that mean I move it one notch over?
Old 12-25-2009, 09:38 AM   #277
Maybe this tech update (PDF) would help you:
Ballistic Motor Timing Update
Old 12-25-2009, 08:41 PM   #278
RFALLON's Avatar
Send a message via AIM to RFALLON
Can I use any sensor wire with this motor? I want to use a TQ 70mm.
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
RFALLON is offline   Reply With Quote
Old 12-25-2009, 08:49 PM   #279
Im pretty sure you can, im using an LRP 75mm sensor wire
Old 12-25-2009, 08:57 PM   #280
RFALLON's Avatar
Alright. I just noticed that the one that came with the motor had two of the wires disconnected, so I just used that as an excuse to get a short wire.
XRAY T2'009
Nexus Racing
KO PROPO
Novak
JR racing
Old 12-25-2009, 10:46 PM   #281
Jochim_18's Avatar
yes one notch towards the positive side. Every mark is 5 degree increments.
Old 12-26-2009, 05:52 AM   #282
lowcel's Avatar
Thank you very much. I'll pull the motor later today and see if I can see it. Is the 13mm rotor faster or does it just allow the motor to run at higher temps?
Old 12-27-2009, 09:00 AM   #283
what do i need to turn my 13.5 balistic into a 10.5 i generally run 13.5 but one track i go to 2 a month only do 10.5 so i thought since 13.5 is my main class why not just buy the parts for 10.5 and get a new 13.5 for race days
so what do i need guys cheers
Burney is offline   Reply With Quote
Old 12-27-2009, 09:36 AM   #284
Originally Posted by Burney View Post
what do i need to turn my 13.5 balistic into a 10.5 i generally run 13.5 but the one track i go to only do 10.5 so i thought since 13.5 is my main class why not just buy the parts for 10.5 and get a new 13.5 for race days
You just need a hand wound 10.5 stator, as shown in this drop-down menu:
Ballistic Spec Hand-Wound Stators
Old 12-27-2009, 10:29 AM   #285
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Very helpful, thanks!
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 11:58 PM
