Old 09-28-2009, 09:15 AM   #211
tfrahm's Avatar
Send a message via AIM to tfrahm
Originally Posted by Sleepstream View Post
With the larger optional rotor, would it make the motor more 'balance'. Hence giving it torque as I've heard the Novak Ballistic is more of an RPM motor. Making it having the best of both worlds. True? Comments?
My experience is that the Ballistic motors are about the same as the SSPro series motors -- it there is any difference, it is slight. If anything, my new Ballistic 13.5 feels like it might have slightly more torque than the older SSPro 13.5 it replaced, but that is probably just because it is "fresher" (stronger magnets, etc.)...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 10-05-2009, 01:09 PM   #212
padailey's Avatar
I just recently switched from a SS to a Ballistic motor and it is really lacking punch. So I'm trying to match the timing on the motor between the two.
My SS felt the same way when I had the timing turned as far down as it would go. On my motor that was the mark on the ring just to the left of the bottom screw as you looked at the back. When I moved the mark just to the right of the screw the motor really came to life.
So my Ballistic was at zero and flat. So I advanced the timing one mark (+). Still flat just got hotter... so should I retard the timing all the way and then advance a notch or two? Or what would you suggest to match the timing of my SS?
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 10-05-2009, 05:02 PM   #213
I run my 13.5 near full timing most of the time has not ran hot and definetly great punch.however I have not ran the ss motor but compared to the other manufactures the ballistic has the best bottom I think.I would crank the timing up maybe change some gearing also when you do that!
Joe Sumasky
joejoe is offline   Reply With Quote
Old 10-06-2009, 07:25 AM   #214
padailey's Avatar
Thanks Joe but I'm running a Tekin RS speedo and as much as I like it I also hate trying to find the "sweet" spot. I thought I'd found it with my SS so I'm just trying to match it with the Ballistic. Otherwise its like starting over.
Tamiya TRF416X
Old 10-06-2009, 08:46 AM   #215
The Evicerator
The stock ballistic timing should be identical to the stock SS pro timing. (30 degrees)
Each tick mark on the Ballistic is approximately 5 degrees of added timing.
The max timing that was acheivable with the SS Pro varies from motor to motor, but it was probably 40-45 degrees on average.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 10-06-2009, 09:48 AM   #216
padailey's Avatar
So the range is roughly the same, meaning if I turn the rings on both motors fully clockwise (or counter clockwise) I would have basically the same timing? I just don't remember where the SS mark was set to start with... unless they were all in the middle of the range like the Ballistic.
Tamiya TRF416X
Old 10-19-2009, 09:36 AM   #217
Company Representative
Default Ballistic Motor updates:
Last week, we released some of our Ballistic wound stators as distribution items, so racers can now purchase stators from their LHS. We will be adding some additional, specialized winds to our store offerings (only): 9.5, 11.5 and 25.5.
We also announced both steel and ceramic individual bearings for our motors. We are also offering two Ballistic motors for crawling, both individually and in Goat 3S crawling systems. Also, the Havoc Pro/Ballistic systems have been shipping for a couple of weeks.
We are also designing a "Build a Ballistic" section for our store. Customers can choose from all of the components for assembly at home (motor in a box); or for an additional fee, we can assemble and test the motor here. The addition of the ceramic bearings and new wound stators will offer even more possibilities for customization.
NovakTwo is offline   Reply With Quote
Old 10-19-2009, 03:37 PM   #218
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
im runnning a GTB (profile 3) and a 17.5 ballistic. im running flat.. it wount even top on the straight away.. running 3.8 fdr..temp is around 139 *, a racer from the track run a ss 17.5 with 4.0fdr ,,he is fast... you think i can turn the timming a little and that will help.. whats the ball park change of temp if i add a 5* of timming.. ?
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 10-28-2009, 03:03 AM   #219
Uga
Uga's Avatar
Anybody knows if Ballistic 10.5T is going to be legal for EFRA Spec class? I was considering going to Birmingham next year..
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 11-02-2009, 04:42 PM   #220
ATLASCOPCO's Avatar
Yes the 5909 13 mm rotor will fit in the ballistic motors
Hi by putting this rotor in what difference would it make
ATLASCOPCO is offline   Reply With Quote
Old 11-06-2009, 05:47 PM   #221
ATLASCOPCO's Avatar
anyone please
Old 11-06-2009, 05:50 PM   #222
JimmyMac's Avatar
More torque, less rpm?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-09-2009, 02:52 PM   #223
ATLASCOPCO's Avatar
Thank you
Old 11-17-2009, 09:55 AM   #224
Default Ballistic Motor Info Update
We have added a category to our Ballistic wound stator offerings called Ballistic Specialty Hand Wound Stators. We now offer the 9.5T, 11.5T, 18.5T, 25.5T---in addition to the Light 5.5T and 6.5T stators.
Motors, with these winds, are not offered through distribution at this time. Our Ballistic stator replacements are separated into 3 categories: Racing, Spec and Specialty.
Old 11-17-2009, 10:01 AM   #225
Jochim_18's Avatar
Waiting for my ballistic 13.5 Motor with mamba max pro combo. I can't wait.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 11:58 PM
