Old 09-16-2009, 03:06 PM   #196
oh yes.. update please on the 25.5 wind.
lots of talk at our home club about 21.5 vta speed.
Dondor is offline   Reply With Quote
Old 09-16-2009, 03:10 PM   #197
The Evicerator
No hard updates yet at far as I know... there has been talk but I'm not 100% on the status of what is going on.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 09-16-2009, 03:14 PM   #198
man that is a setup for a GOOD engineering joke )))
Old 09-16-2009, 06:41 PM   #199
Company Representative
We have already built some 25.5 motors and wound stators. I will check and see when we can get them on line.
NovakTwo is offline   Reply With Quote
Old 09-17-2009, 12:35 AM   #200
hana166's Avatar
Originally Posted by sukh View Post
i ran the old 10.5 and new 10.5 back to back last night, stock timming on both motors, old motor had more speed down the straight, i had to gear up 2 t. on the new motor and 1 more notch advanced timming on the new motor. i was using an LRP stock spec profile 7, motor was comming off at 180-190. will be trying profile 8 next week. other than the slightly slower top speed the motor feels the same as the old ss.
Interesting, I too thought it was slower. Perhaps we need to experiment further.
Still I must congratulate Novak for bringing this motor to the marketplace it sets a new standard in quality, tunability, tolerance of heat etc.. although they already were the standard setter!
hana166 is offline   Reply With Quote
Old 09-17-2009, 04:47 AM   #201
hana166's Avatar
I noticed it was a little crisper to turn over, perhaps it has more torque and should be geared taller..
Old 09-17-2009, 09:07 AM   #202
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
I have the Ballistic 13.5 and it is certainly fast and has good torque. I have noticed that the Duos at our track need to gear quite a bit lower than this motor with their LRP ESCs. When I first ran the car, I had it geared at 5.77 but the car was lacking just a bit of top speed so I geared it up a bit to 5.5 and the motor is fast. The fastest Duo that races here in San Diego and my Ballistic motor are even but his is running a lot hotter. I can probably go up even one more tooth as my temps ranged from 132 to about 150. I run my Ballistic without advancing the timing on the motor itself. I run the KO BMC ESC.
IIGQ4U is offline   Reply With Quote
Old 09-24-2009, 08:09 AM   #203
Contemplating between getting a Novak Ballistic or Epic Duo2. Since both are as good, the Ballistic scores higher marks on the Tunability/Maintenance/Repair.
Someone did tell me they felt the older motor are ever so slightly quicker.
Can someone tell which shop (online) has them in stock & the wound stator as well? (other than shopatron) and its willing to ship overseas (UK).
Sleepstream is offline   Reply With Quote
Old 09-24-2009, 09:00 AM   #204
At this time, we are only offering the Ballistic wound stators manufacturer direct. We are considering making all, or a select group, of the stators available thru distribution. We have had inquiries from re-sellers and are working on a program.
Old 09-24-2009, 09:09 AM   #205
IIGQ4U's Avatar
I am not familiar with the old motor but I really like my Ballistic. The fastest Duo2 that I have raced against was equal in speed to my Ballistic but his temps were higher whereas I could have geared up.
Old 09-24-2009, 07:27 PM   #206
yokemad's Avatar
Has anybody tried to fit this LRP cooler to the Ballistic motors???
yokemad is offline   Reply With Quote
Old 09-24-2009, 09:02 PM   #207
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
yes, but you should run the motor with the center ring, general rule of thumb clip on heat sinks work better/ more efficient on a smooth surface such as a Duo motor as compared to a ribbed surface like on the novak motors
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 09-25-2009, 10:42 AM   #208
We also offer motor cooling kits w/3 different colored HS:
Novak BL Motor Cooling Kit
Old 09-26-2009, 03:45 PM   #209
With the larger optional rotor, would it make the motor more 'balance'. Hence giving it torque as I've heard the Novak Ballistic is more of an RPM motor. Making it having the best of both worlds. True? Comments?
Old 09-26-2009, 04:22 PM   #210
DARKSIDE's Avatar
just got my B21.5...it should be geared as the SS21.5...the motors are the same correct...
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 11:58 PM
