Old 08-23-2009, 07:32 AM   #136
Trader Rating: 20 (100%+)
Originally Posted by wyd View Post
Tekin RS software V200. 30 Timing with 10 Turbo Boost. Track is 100x47 indoor high bite asphalt. Geared 20/75 at 5.14 in a Team Magic E4. Car was great and a combination of the car cornering well and with the gearing and motor all working together made for an excellent running car for me today.
To be honest as good as my car was I would still like to try the Novak Havok Pro exc wheen available because as nice as the Tekin is sometimes I would like to leave the laptop at home and just gear up and run. All these fance speedos are nice but something to be said about simple and just overall good working speedo. I don't always want to drag the laptop around.
Hey Wyd,
Did you change the timing on the motor? Just curious cos i'm assuming the 30 degree timing is on the speedy and not the motor. If you did change the timing on the motor what did you set it to? I'm goin to be running pretty much the same setup.
Cheers
bee200sx is offline   Reply With Quote
Old 08-23-2009, 08:58 AM   #137
Company Representative
Originally Posted by mrrcguy View Post
Thanks. Is this bearing available separate form the end-bell are is that the only way to get it?
We plan to add bearings for the Ballistic to our motor accessories.
NovakTwo is offline   Reply With Quote
Old 08-23-2009, 12:13 PM   #138
adamge's Avatar
Originally Posted by Team_Elli View Post
Thank's i have pretty much bought wrong pinion's then i thought maybe between 6.0-5.0 some place but no oh well, just have to buy between 6.0-7.0 then at least i get a good selection of pinion's now
On a medium traction 42x75 ft track, I ran 6.67 yesterday and was showing temps around 145degF. So, I can gear higher, probably to 6.25. Can you instead replace the spur to achieve these 6-7 ratios?
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 08-23-2009, 01:41 PM   #139
Sure i can replace, but the prices is the same as the Kawada 64p pinions that i have bought as the Xenon spur gears that i need to use for the Photon Foam spec that i am going to drive this winter
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 08-23-2009, 04:23 PM   #140
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by bee200sx View Post
Hey Wyd,
Cheers
I used the stock factory set timing on my Ballistic. The motor itself has 30 degrees of timing. Steve Weis posted that info for me. Now like Steve said alot of people measure timing many different ways so take that info and just use it for a referance point when using Novak motors. The motor worked great for me with the stock setting.
ST Racing Concepts (STRC)
Old 08-23-2009, 05:02 PM   #141
SWTour's Avatar
These are such an awesome beast!! NOVAK outdid themselves building this motor!!!
Just in case any of you haven't seen one of the Ballistic motors torn down - they are THIS Simple!!
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 08-23-2009, 05:55 PM   #142
Armaan's Avatar
Trader Rating: 49 (100%+)
Awesome, thanks!
Armaan is offline   Reply With Quote
Old 08-23-2009, 07:42 PM   #143
Registered User
UltegraSTI's Avatar
broke down and bought a 17.5 and the 8.5 stator after hearing bout the versatility.
R
UltegraSTI is offline   Reply With Quote
Old 08-23-2009, 08:25 PM   #144
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
so are these 21.5's faster than the ss 21.5's?
Alex
hound_dogs_01 is offline   Reply With Quote
Old 08-23-2009, 08:32 PM   #145
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
R
Where did you purchase the stator?
mrrcguy is offline   Reply With Quote
Old 08-23-2009, 08:43 PM   #146
Trader Rating: 31 (100%+)
From what I understand, it is the same motor as before except very much thought out. All in all it is a better motor idea.
NovakTwo, I heard Novak now has graded rotors measuring 1300 or better with a gauss meter. I have 4 ballistic motors in my possession and each rotor measured under 1200. Are the graded rotors an aftermarket purchase?
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 08-23-2009, 08:59 PM   #147
wyd
Tech Legend
wyd's Avatar
Damn 4 of them already!!!!!!!!!!!! Your my hero.
Old 08-23-2009, 09:02 PM   #148
wyd
Tech Legend
wyd's Avatar
R
HEHEHE see what I talked you into. You will like the motor. Like Jamie said they are well thought out.
Old 08-24-2009, 08:15 AM   #149
Joe: Thanks for posting the photo of the dissasembled Ballistic 21.5 motor. I had only seen our exploded diagram for a guide to how it was put together.
Mrrcguy: We are selling the wound stators on-line. We are offering the modified winds, the spec winds (with colored inserts) and two light winds.
Jamie: We offered a small number of factory-magnetized graded rotors. There are none available now. But, we may offer them again in the store.
Hound: We are not claiming that the Ballistics are any faster, or higher performance, than our SS 21.5 Pro motors. But, we are inviting inputs from racers who have experience with both.
Old 08-24-2009, 09:58 AM   #150
wyd
Tech Legend
wyd's Avatar
Well Novak sales are Ballistic in my area now. Had mine 2 weeks and now I had two buddies picks them up, another buddy PMed about getting one and my shop I help out at just got in two Ballistic motors and will be ordering in parts for them as well.
I don't know if the Ballistic is any faster because I never ran another Novak motor but for convience this motor has no equal right now. What other motor can you burn up the winds and order a replacement for 30 bucks!!!!!!!!!! Then buy a different wind for 30 bucks and have a motor for another class. Just excellent engineering on Novaks part and right now the leader of the pack when it comes to this motor and replacement parts. Someone was thinking when making these. Very well thought out.
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 11:58 PM
