Old 03-30-2011, 03:30 PM   #1201
don't know if this is the right thread (I did ask on another because I'm not sure) I have a blue 120A Xerun ESC. I love it but my firmware is probably several versions old. I have no idea how to update it and my software and my LCD box and which versions I want.
I run it with a Castle 1410 4 pole motor or a 550 size Novak 4.5T in my 4x4 short course truck. Can anyone tell me which versions of everything would be best and point me to a tutorial or instructions on how to update everything?
Thank you!
(also if there is a thread that already covers this or a link to another site that would be fine as well)
chiro972 is offline   Reply With Quote
Old 03-30-2011, 04:06 PM   #1202
cherry2blost's Avatar
Thank you!
Here is a link there is the latest firmwares and tutorial videos as well.
http://www.rctech.net/forum/8885410-post1.html
Hope it helps
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-31-2011, 06:05 AM   #1203
Hope it helps
Cheers mate!
Old 04-09-2011, 09:07 AM   #1204
Default Hobbywing 120A v2.x burnt
My hobbywing 120A v2.x burnt, anyone knows what is the electronic component inside the picture. Thanks.
vones325 is offline   Reply With Quote
Old 04-09-2011, 09:25 AM   #1205
ali_g's Avatar
guys, care to clarify what is the latest software?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 04-09-2011, 10:22 AM   #1206
version 2.0
Old 04-09-2011, 11:24 AM   #1207
ali_g's Avatar
Originally Posted by vones325 View Post
version 2.0
u sure?? i meant software version
☆ JU.C RACING ☆
Old 04-09-2011, 11:59 AM   #1208
dameetz's Avatar
its fw 211 cant remember the whole numbering though.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 04-09-2011, 09:25 PM   #1209
On the PCB, it's marked "HW427v1.2"
Old 04-09-2011, 09:29 PM   #1210
On the PCB, it's marked "HW427v1.2", the picture before burnt.
Old 04-10-2011, 12:32 AM   #1211
Looks to be a conformal-coated tantalum capacitor. Can't tell what value it would be but a safe bet to try would be a 4.7uF or 10uF 16V tant. Tant caps are polarised (have a +ve and -ve end) and looking at the white rectangular silkscreen the positive end is towards the bottom of the pic.
rwpease is offline   Reply With Quote
Old 06-08-2011, 01:34 PM   #1212
Running an 8.5T with a XeRun 120A v2 for a drifter. Came with firmware V1.10_090205_MOD and I flashed it to V3.0_110119_MOD. I now see settings to enable boost/timing advance. From what I read I shouldn't be using boost/timing advance with a motor faster than 13.5T, and for drift it's really overkill and unnecessary. I do want to run some timing advance because I've read and experienced a little cogging at low speeds without timing.
In this new firmware, I don't see the ability to get timing to 20+ degrees in non-turbo mode. Is there a list of the updates to each firmware version?
Also, lastly, does the fan ramp up based on temperature? It's screaming loud without the car even running, and I know drift doesn't stress the motor/ESC much.
liquoredonlife is offline   Reply With Quote
Old 06-08-2011, 06:16 PM   #1213
There is no list of changes for the various firmwares, to anyones knowledge. And the Fan runs directly off your battery voltage.
Dont know much about MOD versions of the FW though, sounds like the 508 Stock "Blinky" might be a better choice for your application.
Shawn
Shawn68z is offline   Reply With Quote
Old 06-23-2011, 04:12 AM   #1214
Default what cord to use to connect programme card
Sorry to ask such a duymb question but I need to know how to connect my programming card to esc with, it has an internal BEC but no seperate cable to the reciever and the instructions tell me use that cord? Im assuming obviously I would just use the only cable that there is and connect the lipo and see what happens? Is there someting Im missing?
driftcrazy is offline   Reply With Quote
Old 06-23-2011, 10:52 AM   #1215
JKL1031's Avatar
there is some info on changes if you fumble around in the readme file(or one of the others) of the software package.
http://www.youtube.com/watch?v=5PRcsM7ccms
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
