XERUN V2.0 Brushless ESC discussion thread. >
Old 11-14-2010, 05:10 PM
  #1141
nikos2002's Avatar
Trader Rating: 30 (100%+)
Guys both of my 120's did something strange today. After running for about 20 seconds they would act like the thermal went off, cutting voltage dramatically, the car would roll for about 10-15 seconds. Then burst back into life, full power, for 20-30 second and same cycle again. It happened with one car using a 8.5 (mod profile software) and another using a 17.5 (stock profile software- no turbo). Neither was even hot to the touch. Both had fans and caps on. My 60 (with no cap) and a 10.5 ran flawlessly.
Any ideas?
nikos2002 is offline
Old 11-14-2010, 05:15 PM
  #1142
what batt pack and how old is it?
cheapskate.brok is offline
Old 11-14-2010, 07:59 PM
  #1143
nikos2002's Avatar
Two different packs. One is 1 month old SMC, the other is a year old checkpoint. Both worked with the 60a esc.
Old 11-14-2010, 09:09 PM
  #1144
nikos2002's Avatar
1/2 the issues solved - on the esc using the 8.5. The A wire (negative) was slightly loose - I mean really slightly. But it made a pretty good arc, then I touched it.
Still chasing down the other esc. It's late will look at it tomorrow. Including a re-flash of the software.
Old 11-14-2010, 09:57 PM
  #1145
razzor's Avatar
check your soldering on esc and motors as this can also cause problems.
razzor is offline
Old 11-14-2010, 10:50 PM
  #1146
RevMaxx's Avatar
what is your voltage cut-off setting? try lowering the voltage cut-off back to 3.0V.
RevMaxx is offline
Old 11-15-2010, 07:54 AM
  #1147
nikos2002's Avatar
Didnt think if that Rev - I run 3.4 (like to be ultra safe)- I run offroad so run time is no issue.
All the solder joints on the 17.5 car were good. I am also going to check the sensor tab in the motor. To see if I can see any issues.
Thanks for the help everyone.
Old 11-15-2010, 08:57 AM
  #1148
th4433's Avatar
Default Xerun
I have been very happy with the Xerun 120A ESC. However i have major problems with their motors.
th4433 is offline
Old 11-15-2010, 12:53 PM
  #1149
TeamWTF's Avatar
I have not had a problem with the motors... though i have one and only used it for one meeting
It seemed OK. I thought it ran a little warm compared to other motors i had run, but then again it has no holes in the can for air to flow..... which i will fix before the next race...
Its a 10.5t.... It seems to rev a little less when no timing is applied... so my question is how much advance is built into the motor?
TeamWTF is offline
Old 11-17-2010, 05:05 AM
  #1150
Default XERUN problem
Hi guys,
Last Saturday, I ran my XERUN 120 Amps with a 13.5T motor. A fews laps after I started, the car started to loose power in certain parts of the straight. It will boost for a quick moment then suddenly loose power as if I was running a silver can motor. There were portions of the track where there would be full power and there would be some where it has none, consistently. That happens when I ran it on NiMH. It happens less on a LiPo.
Yesterday, I ran it again and was ok again with the LiPo, but noticed that the motor was running really hot, ranging from 140 to 170. Finally, just before heading home, I tried running another pack of NiMH, then the unfortunate event happened, the car shut down on the track. When we did the temp, it was 180.
I went back to the pit and cooled down everything. When I turned my esc on again and try pull the throttle, it was doing very short bursts for a moment and died. We tried to do an initial set-up and the lights were responding. I placed the program card and it was reading the esc's profile. I changed receivers and batteries and it is still dead. One thing I notice though is that the only thing not responding was the motor. My servo was working fine and all the fans go on when I turn the ESC on.
Any thoughts you may have regarding the problem will be greatly appreciated. Motor, ESC or both? Please advice. Thanks.
speedykupad is offline
Old 11-23-2010, 04:43 PM
  #1151
Questions?? I am getting similar problems too
I was racing tonight with 518 software, as I have always done. I would drive for a short time, and then the car would go about a 3rd slower. If stopped and switched off then back on it was ok. Of my four runs tonight, I only had one fast run.
Someone suggested I re-install the firmware, can it be something else. BTW i used a new battery pack, and the motor did not get hot.
Lohan is offline
Old 11-23-2010, 04:47 PM
  #1152
why isn't there anyone talking about the Xtreme Stock 60A?
Old 11-29-2010, 02:02 AM
  #1153
steliosh's Avatar
A peculiar question, here...
So as not to buy a new Ezrun 60A, can I use my spare Xerun 60A to power an 8.5T sensorless Ezrun motor on my son`s 4wd buggy?
Will this combo work?
I wonder!!!
steliosh is offline
Old 11-29-2010, 02:20 AM
  #1154
It could be because the thread is about the Xerun series of esc:s
snabbgas is offline
Old 11-29-2010, 06:05 AM
  #1155
ROTFL
