Old 08-16-2010, 11:24 AM   #1081
Originally Posted by tomislav View Post
I jave just receive my second xerun this time 60a version and on this is 14awg
Wire and smal capacitor board. Can i benefit from 12awg wire and capacitor Like on 120a version or 60a version don't need this upgrade.
Is this capacitor ok to use? I have speedpassion super capacitor board probably better then this one.
I use 10.5t motor pushed to the limit so it's Like running 5.5 or 6.5 without turbo timing.
Can i use same setup as on 120a for 10.5t motor?
Just leave it alone. I have a 60A and theres absolutely no difference in performance with a 120A.
maxg123456 is offline   Reply With Quote
Old 08-16-2010, 01:05 PM   #1082
cherry2blost's Avatar
No problem whatsoever changing the wires to 12AWG, may give less voltage drop but if your wires are as short as they should be then the V drop will be negligible anyhow...... Certainly for the 'longer' battery wires there may be a measurable difference, but for all the hassle of de soldering the wires and the resultant heat return to the speedo it probably isn't worth the hassle.
Now the 4 part Capacitor........ personally I like the bigger capacitor, seems to reduce heat in both the ESC and the Motor, also is considerably easier to mount than the side by side layout on the 2 part capacitor board, i personally tape it down the centreline of the chassis next to the belt as this is neatly hidden and nicely protected from knocks etc, again you may notice a difference but then again you may not.
Pays your money etc......
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 08-18-2010, 01:36 AM   #1083
It's safe to use turbo function on a 60A ESC?.
What's the motor limit for the turbo?
prorace is offline   Reply With Quote
Old 08-18-2010, 04:25 AM   #1084
I've ran full turbo and boost with a 10.5 before. I'm sure you can go to an 8.5T, but on lower settings
Old 09-08-2010, 01:47 AM   #1085
xl8er's Avatar
hey can someone please tell me if this is the same as the hobbywing esc. if so what program card do I need?http://www.hobbyking.com/hobbycity/s....2)&aff=12350t
damn you must be fast because you were move'in when I passed you
xl8er is offline   Reply With Quote
Old 09-08-2010, 01:55 AM   #1086
razzor's Avatar
That looks like the HW EZrun 60amp esc.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-16-2010, 04:15 PM   #1087
Hi, Xerun drivers.
The forum is not buzzi at the moment, it's pitty because I see the Xerun 120
become faster and faster, and this we al looking for.
And realibillity is quit good.
Show some settings for 13.5 and 4.5t for TC if you like.
Let not all the work to be done by cherryblost he is a great guy and
share all he knows.
Ed
eded1 is offline   Reply With Quote
Old 09-16-2010, 04:36 PM   #1088
mc4798's Avatar
Anybody run these in a 10th scale buggy ? maybe 13.5t class ?
mc4798 is offline   Reply With Quote
Old 09-17-2010, 02:56 PM   #1089
I've run this ESC in my B44 buggy with a 10.5t and its keeps up with
6.5t cars.
Old 09-17-2010, 04:32 PM   #1090
mc4798's Avatar
6.5t cars.
Thanks.
Thats what i needed to know. Was wondering how it would fit in a b4.
Old 09-19-2010, 07:25 AM   #1091
Thanks.
For a B4 it is the smoothest ESC you can find
Old 09-23-2010, 04:36 PM   #1092
mc4798's Avatar
Yes it is Best investment in brushless I have made. Simply put love it.
Now for another question.
Just got a Ofna Hyper 10sc , Is it possible to use this esc for a 550 size 5.5t motor ?
This is the motor Im gonna use by the way.
http://www.teamepiconline.com/shop/i...p?item=TEP1034
Old 09-23-2010, 06:56 PM   #1093
AdminD's Avatar
as far i know it wil do just like sp gt does, but im not sure wit the stock firmware, but the mod firmware will do.
Sliders
AdminD is offline   Reply With Quote
Old 09-24-2010, 03:13 PM   #1094
Questions?? XeRun 60A
Hi all,
I have a XeRun 60A V2.1 in my Yokomo Bmax4 together with a Ballistic 7.5 with a roll out of 9.0.
Speedo and lipo are around 40C and motor at 62C after a 8 - 10 min run on an Astroturf track.
Software is V1.10_091218a_t which I think is an old version (version 27). Punch is at 5 and timing at max.
I would like to have some more top end on the straight, smoother acceleration (more lineair) out of the corner, better brakes and cooler temperatures of the motor.
Which software version is advised?
Probably a lot to ask for but it is not really clear which are the best softwares per application.
Thanks in advance.
kusal is offline   Reply With Quote
Old 09-24-2010, 04:01 PM   #1095
This motor is for the Xerun60A in my opinion to heavy, but compair the specification of both motors and look to the amps they consume.
If this is close then it is OK if not you have to purschase the Xerun120A.
Good luck
Ed
