Old 07-22-2010, 07:36 PM   #1051
cherry2blost's Avatar
Originally Posted by Andysan View Post
I need to plug ESC into LiPo and turn on even when connected to PC? I assumed that the battery only needs to be connected and switched on to power the programming box - as this is powered by USB I didnt think it was necessary.
Its not the speedo I'm concerned about, its that Im plugging something into my USB port thats plugged into a LiPo battery - with other ESC's I've read not to do this because you could send voltage into your PC and damage it.
Definitely then to access the speedo plug the LCD box into PC, speedo into LCD box and then power on with LiPo battery and switch? I'm still cautious.
Cheers!
My tutorial videos may help, they take 15 minutes between them but I think they will answer your question matey.
Part 1 http://www.youtube.com/watch?v=bUKMoGvRJZY
Part 2 http://www.youtube.com/watch?v=iOCFkCwBlrQ
Trust me its fine been doing this stuff for ages it won't blow you laptop.
Hope it helps
Cherry xx
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 07-22-2010, 09:20 PM   #1052
Trader Rating: 22 (100%+)
Cheers!
AS I said you must have the speedy turned on and plugged in, that is the way the PC and ESC communicate.
No problems with my computer doing this at all.
bjspinner is offline   Reply With Quote
Old 07-23-2010, 02:38 AM   #1053
Andysan's Avatar
Just tried this thanks and I can now access the ESC OK, cheers for that. Sorry for asking twice, just hadnt seen it mentioned explicitly and I have recently bought a rather new expensive PC!
Hope it helps
Cherry xx
Thanks Cherry, I had watched each video a number of times and found them very useful for identifying the different settings and flashing the LCD box firmware twice etc... so if I ever bump into you remind me that I owe you a beer!
However, I dont recall that either video mentions whether the battery should be plugged in and the car switched on when hooked up to the PC, although I could be mistaken.
Thanks for taking the time to help everyone out with your vids!
Andysan is offline   Reply With Quote
Old 07-23-2010, 03:03 AM   #1054
LOL you're welcome, when I can find a clear afternoon am gonna do updated video, keeping it below 10 minutes for the whole and will add in the bits and bobs people have mentioned.
Happy Hobbywinging
Old 07-23-2010, 06:50 AM   #1055
Andysan's Avatar
Happy Hobbywinging
Sure, I think the videos are very good and in no way meant it as a criticism but I notice that on other forums there are a few other people as thick as me who had the same question so maybe worth including it.
Will look forward to the next video!
Old 07-23-2010, 10:13 AM   #1056
K_Takuya's Avatar
Hi all,
I need your help,newbie here. what is the best setting for the esc using the program card? Im confused especially with the drag brake, initial brake and brake force.
Im using ezrun 60A 5.5T for touring...
Bodyshell+kit+bateri+remote+receiver+tayar+rim+esc+charger = Jom main!
K_Takuya is offline   Reply With Quote
Old 07-26-2010, 04:57 AM   #1057
Originally Posted by darrenoakley View Post
Hey chaps just wondering if there is any difference between the 60a SD and the 60a SL244. The spec looks the same apart from in the picture the later has a fan.
Thanks in advance guys
and i am still trying to find an answer for that.
please anyone can clarify this.
thanks
khaledome is offline   Reply With Quote
Old 07-26-2010, 03:51 PM   #1058
tmkhaw's Avatar
Send a message via MSN to tmkhaw
Default 120A vs 60A dimensions
Hi,
I would like to know if the 120A XERUN is the same in dimensions as the 60A XERUN.
I just purchased the 120A XERUN, however the fit in my F104 is a little too tight and I'm thinking of purchasing another 60A XERUN.
On the site, the dimensions are actually identical. Is that accurate?
Thanks in advance.
tmkhaw is offline   Reply With Quote
Old 07-26-2010, 04:31 PM   #1059
Originally Posted by tmkhaw View Post
Hi,
Thanks in advance.
I've got both the 120A and 60A versions, and yes they are the same size.
-Jeff
blanchjd is offline   Reply With Quote
Old 07-27-2010, 12:19 AM   #1060
razzor's Avatar
The new Xtreme has a smaller footprint but not sure who has them instock yet.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-27-2010, 03:01 AM   #1061
tmkhaw's Avatar
Hi,
Thanks in advance.
Alternatively, do you think I could run the ESC without the fan? I'm running a TP 17.5 motor and using the 528 s/w.
What should be a safe operating temperature limit for the ESC?
Old 07-27-2010, 04:14 AM   #1062
We run 10.5's without the fan using 528 is no problem so far.
Old 07-27-2010, 04:36 AM   #1063
AGNO's Avatar
I confirm, with 10.5 not use the fan and no problem with teperature environments high (30/35 C)
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 07-28-2010, 01:06 AM   #1064
tmkhaw's Avatar
Hi,
Thank you very much guys.
So keeping the ESC in 30-35C range should be safe? I am running in tropical climate, so still feel some reluctance to remove the fan.
The fan is actually quite loud, seem to be louder compared to other brands.
Out of curiosity, will we have longer run time by removing the fan?
Thanks.
Old 07-28-2010, 04:28 AM   #1065
kuanseng1981's Avatar
Trader Rating: 15 (100%+)
Hi anyone can advice what final drive for a 9.5 brushless on a buggy with the tubro software.
Friends come and go,
who's your friend nobody knows,
till the time than it will show,
who is friend who is foe.
kuanseng1981 is offline   Reply With Quote
