XERUN V2.0 Brushless ESC discussion thread. >
Old 06-26-2010, 05:46 AM
  #1006
darrenoakley's Avatar
Hey chaps just wondering if there is any difference between the 60a SD and the 60a SL244. The spec looks the same apart from in the picture the later has a fan.
Thanks in advance guys
darrenoakley is offline
Old 06-26-2010, 07:04 AM
  #1007
razzor's Avatar
Having run the SP GT, LPF as well as HW 120A and 60A i can confirm that there is no difference in performance if you run 17.5, 13.5 or 10.5.
What makes all the difference is the software used and driver ability.
If guys motors are running hotter then they should look at there setting being too aggressive or overgeared.
Heat essentially comes from inefficiency/wasted power not because its getting more amps.
razzor is offline
Old 06-26-2010, 07:35 AM
  #1008
Hi guys
Not long been back to racing after about 5 year brake and picked up a HW from Hong Kong to put in my TC it worked ok with standard settings but now i want the turbo timing but i could only seem to download the SP one using there USB link but on my HW 2 in 1 program box. The problem i have is that now i cannt change the car setting with just the box i need to be conected to the lap top ? is this normal ? The car seems ok tho sounds like a lot more revs there i mean ALOT but not on the track till tuesday night so no test yet but hope to start to find a set up then....
Thank
Darren
dazzzza is offline
Old 06-26-2010, 12:10 PM
  #1009
cherry2blost's Avatar
HobbyWing site is down, here is a download link for 1.62 for use in the interim.
Here is a linky to 1.62, it should be good for you, it will update to 1.63 as soon as the HW site is up and running but apart from 528MOD it is the same as 1.63.
Download Hobbywing_USB_Link_setup_V1.62_100520.rar from FileFactory.com
Hope it helps
Cherry
cherry2blost is offline
Old 06-27-2010, 01:45 AM
  #1010
LOSI123's Avatar
Trader Rating: 63 (100%+)
anyone know this, i wanted to know as well, also noticed one of them has wires already soldered on in the pictures as well.
LOSI123 is offline
Old 06-27-2010, 02:12 AM
  #1011
Also there is a price difference, only about 8.00 uk ut still cheaper. But really wanted to make sure i got the right one.
Old 06-27-2010, 10:19 PM
  #1012
yobouno's Avatar
can you upgrade v1.0 ESC with a v2.0 firmware?
To Xerun and Ezrun?
Finally, decided to bite the bullet and get a program box. Buying LRP is costing me a fortune.
yobouno is offline
Old 06-27-2010, 10:25 PM
  #1013
cannon's Avatar
Trader Rating: 35 (100%+)
To Xerun and Ezrun?
No I believe not.
cannon is offline
Old 06-28-2010, 12:00 AM
  #1014
yobouno's Avatar
Originally Posted by cannon View Post
No I believe not.
So with all these new timing stuff it only applies for V2.0 of the Xerun?
Bummer. I was hoping my Venom 120A can benefit from the dynamic timing stuff. Any advise to make the Venom 120A perform better?
yobouno is offline
Old 06-28-2010, 12:19 AM
  #1015
Some of the later USB enabled v1.1's can be flashed but only with software versions to which the Ver_control recognises, I thought the Venom and the Muchmore Fleta WERE v 2.0's to be honest though.
Someone correct me if I am wrong on either point.
Old 06-28-2010, 01:18 AM
  #1016
Pablo Diablo's Avatar
I have seen Venom 120A's running HW firmware.
Pablo Diablo is offline
Old 06-28-2010, 01:26 AM
  #1017
cannon's Avatar
Danjoy from Venom should be able to answer this.
cannon is offline
Old 06-28-2010, 02:41 AM
  #1018
veecee's Avatar
Trader Rating: 34 (100%+)
Pretty sure the V2 Venom's can be updated but not the V1. Same as Hobbywing I guess.
veecee is offline
Old 06-28-2010, 03:57 AM
  #1019
yobouno's Avatar
cool thanks. BTW, how to tell between V1 and V2?
yobouno is offline
Old 06-28-2010, 04:40 AM
  #1020
veecee's Avatar
V2 has a see-through green case. From memory V1 has a chrome green case that is not see-through.
veecee is offline
