XERUN V2.0 Brushless ESC discussion thread. >
Old 06-17-2010, 02:34 AM
  #961
ali_g's Avatar
Originally Posted by Humyu View Post
Anyone has tried the new 528Mod software? How the go??
i have tried the software, gives the motor bit more punch when u need it.
Motor temp was under 80deg after a 5mins qualifying
ali_g is offline
Old 06-17-2010, 01:34 PM
  #962
What is the difference between 528mod and 528stock? Are the stock settings more aggressive?
garycoleman is offline
Old 06-17-2010, 11:35 PM
  #963
Humyu's Avatar
what motor turn you using and whats ur setting.
Humyu is offline
Old 06-17-2010, 11:38 PM
  #964
Humyu's Avatar
Don't think the 528S is out yet, maybe still under RnD. But with the 518stock it's no recommended to run MOD motor or ur motor will blow. Maybe 528S is more aggressive.
Humyu is offline
Old 06-18-2010, 03:03 AM
  #965
Default Where to buy Xerun
Someone was interested at Maritime Raceway yesterday where to get the Xerun. Here's the place!
http://cgi.ebay.co.uk/XERUN-120A-SD-...item5887247fbc
maxg123456 is offline
Old 06-18-2010, 03:47 AM
  #966
ali_g's Avatar
i was using HW 4.5t motor, most of the turbo settings are as per recommended i only play around with #13 boost start rpm and #14turbo delay.
I managed to qualify 5th among the LRPs,Orion powered cars and finished 4th in the finals.
ali_g is offline
Old 06-20-2010, 05:11 AM
  #967
xrayal's Avatar
a 60a v2 for less than 48.00 delivered. flea bay item number 390210549133 unreal. wonder how much cheaper they will be when the new speedo comes out..................
xrayal is offline
Old 06-20-2010, 08:32 AM
  #968
zookey's Avatar
Trader Rating: 19 (100%+)
Default sp v1.1
Hi guys just had a question I have the hobbywing blue spirit esc 120A and love it, but just wondered I also have an old speed passion Grand Turismo V1.1 am I able to upgrade and install this the turbo firmware at all or was that feature only avail on the newer models?
zookey is offline
Old 06-20-2010, 09:09 AM
  #969
razzor's Avatar
the v1.1 was is no updateable but still runs great for mod.
razzor is offline
Old 06-20-2010, 11:10 AM
  #970
cherry2blost's Avatar
Thanks Al, seemed rude not to!!! So ordered one
cherry2blost is offline
Old 06-21-2010, 12:09 AM
  #971
mlight13's Avatar
Trader Rating: 40 (100%+)
Quick question, I just loaded in SP firmware 100110_STOCK into my HW XeRun 60a/13.5 combo as I will be racing in a non-boost TC class. I believe this was the last non-boost firmware other than the 508 which as ZERO timing which is not being raced by me yet. Question is, what is a good starting FDR and timing setting for a medium sized asphalt track? Should timing be set at the highest (26.25) or just under that? Thank you...
mlight13 is offline
Old 06-21-2010, 02:18 AM
  #972
razzor's Avatar
Start with timing at 18 and go up 1 position after a run and note if it does improve .DRSS at 7 to start and go more aggressive if needed from there.
around a 35 - 37mm roll out would be a good start for gearing.
razzor is offline
Old 06-21-2010, 02:14 PM
  #973
xrayal's Avatar
it means that you can now get a speedo with turbo etc for 47 and an xerun 10.5 motor for 38 delivered.85 for mad speeds!!!!!!!!!!!!!!!!!!
thank you hw.
xrayal is offline
Old 06-21-2010, 08:38 PM
  #974
COBRARACING's Avatar
Hi guys
the new 120 esc is called the 2.1 not the v3 it is a smaller package though.
Also as of next week the 120 amp 1s will be available ill keep you posted
COBRARACING is offline
Old 06-22-2010, 05:18 AM
  #975
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by COBRARACING View Post
Hi guys
Angelo,
There has been a Vers 2.1 around for a short while. It is different in that it has a two cap board instead of the older large board. Is this the Vers 2.1 you mean? I have seen some but to be honest never bothered to check to see if the ESC was smaller
cannon is offline
