XERUN V2.0 Brushless ESC discussion thread. >
Old 06-09-2010, 11:16 PM
  #916
RevMaxx's Avatar
is it OK to run the turbo boost of the Xerun 120A using a 10.5T motor?
RevMaxx is offline
Old 06-09-2010, 11:18 PM
  #917
COBRARACING's Avatar
Yes you can 100% sure .
COBRARACING is offline
Old 06-09-2010, 11:30 PM
  #918
Originally Posted by warnos View Post
Got a good testing session with the 120a with the 518 software in 21.5 and 17.5.. I think I am going to be converted no more using my Tekin.. The speedie has a little bit more down the straights then the tekin right at the end of the straight.. feels allot smoother and has more punch through the infield... man I can't believe I putting a $250+AUD speedie on the shelf for one that I purchased for under $100AUD off ebay as a backup.. awsome.
I am running no drag brake but the speedie seems to have more natural drag through the corners when compared with the tekin.
There is one problem I found (well not a problem just a diet issue).. far out this speedie is heavy.. on a Cyclone Exotek I had to go down to 4200 batteries from 5000 with 15g weight to be on weight with the tekin rs and had to slide the battery out to its wides setting to keep the car balanced.
Anyone running this speedie without a fan.. I know it states to run a fan when using the new firmware with adjustable timing.. I just thought a 120a might be able to handle 17.5 or 21.5 with the fan removed.
Cheers
There is plenty more going to come out of hobbywing they are on a roll now and they understand what the western world requires from them whenit comes to quality and technology .
Believe it or not Michael from hobbywing had designed the turbo timing software way before any other company but because he wanted it to be perfect and didnt want the motors to run so hot he took his time with testing .
Believe me when i tell you these guys have got it right no more sitting in the shadows of others it's time for them to show the world what they are capable of .
Be on standby for more good news and yes the V3's will be available soon .
Old 06-09-2010, 11:33 PM
  #919
Cheers
The new xtreme stock is lighter and smaller .
Old 06-09-2010, 11:50 PM
  #920
cherry2blost's Avatar
Cheers
Run the fan mate, it weighs bugger all compared to the ESC lol, why take the chance.
cherry2blost is offline
Old 06-10-2010, 02:35 AM
  #921
I ran a Fan on the ESC Sunday (it was quite hot here in the south of UK). Took the temp down from 58 Degrees C to 36 Degrees C. The motor also dropped in temperature 10 Degress c???? is this a coincidence or does running the ESC cooler mean less heat into the motor?
geubes is offline
Old 06-10-2010, 02:52 AM
  #922
warnos's Avatar
Do you know what the difference in the V3 will have over the V2 will be? Is the firmware and features going to be the same for both.. or are we looking at getting new ESC's soon to keep up..
Cheers
warnos is offline
Old 06-10-2010, 07:44 AM
  #923
hi all
I've just buy a hobbywing product and arrived less then a week, Ezrun motor brushless combo 9T ESC 35A plus program card from ebay seller.
There is some problem in my product, how can i solve this problem??
for your information, here is some problem:
1. Power of the motor between forward and reverse has different. I think this is something wrong, as i know power of the motor between forward and reverse must same. How could this happen??
2. First installment, the program card has 11 menus(because i used NIMH batteries, if seen on the program card menu will be appear 12 menus if using LIPO batteries) and then after first time installment the menus become 10 (number 11 menus motor rotation has dissapear). How could be happen??
for the first time installment, i was follow all the instruction from the hobbywing manual online and im sure was correct.
with this problem, please kindly help me to solve it.
fnd5500 is offline
Old 06-10-2010, 08:47 AM
  #924
beaim's Avatar
Trader Rating: 8 (90%+)
wrong post. sorry
beaim is offline
Old 06-10-2010, 12:33 PM
  #925
Default hobbywing
the xerun is amazing. Put it in my WGT car which I had my tekin in and was faster. Love the program box but need some help with the drag break. My choices are upto 30 perc than my next choice is 100 percent. How do I add my break for about 60 percent?
bigdanes is offline
Old 06-10-2010, 12:43 PM
  #926
Custom setting via the software.
Once you set it in the software then anytime you select custom in the LCD it will be 60% or whatever you manually put in.
g26er is offline
Old 06-10-2010, 03:33 PM
  #927
Originally Posted by fnd5500 View Post
hi all
I had the older version from about a year ago and I remember that one of the settings is for reverse strength. Use that to adjust the power for reverse. No idea about motor rotation since mine didn't have that option.
Threg is offline
Old 06-10-2010, 03:42 PM
  #928
Originally Posted by DriftMonkeys View Post
question am trying to update the firmware on my xerun i have the v2 lcd program box but now idea on how to use it on pc or were to find the updates on the net ...?
so i need help on were to start ????:
www.hobbywing.com
Look for the LCD program box and there's a link at the bottom to download the latest software. Site is down at the moment.
Threg is offline
Old 06-11-2010, 05:02 AM
  #929
I'm running the 60A version without a fan. Its no problem at all with a 10.5!
I cannot believe how smooth this esc is with my 13.5 GM on a tight indoor track. (where you need it!) My Timing punch I turned down to 6 (-5) and everything else is basically maxed out. Its great to be able to use all the power for top end speed without overheating the tires getting there!
Cheers
maxg123456 is offline
Old 06-12-2010, 03:47 PM
  #930
Hi
Ive been running 518stock cause I thought it was a little smoother than 422stock.
I was wondering if anyone had tried 528stock yet?
TBOTubed is offline
