XERUN V2.0 Brushless ESC discussion thread. >
Old 06-03-2010, 08:18 PM
  #871
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
what radio ?
ozzy-crawl is offline
Old 06-03-2010, 09:23 PM
  #872
Originally Posted by ozzy-crawl View Post
not sure if i am getting the same problem with my xerun 80a and dx3s
now and then i pull the trigger and there is nothing or it starts to take of and cuts out,runnig 2s 30c 5000s so its not a voltage loss under load issue i dont think.
must be the bec, mite try a ubec and see what happens
do you know witch wire i would have to remove from my esc red or black
steve1986 is offline
Old 06-03-2010, 11:10 PM
  #873
razzor's Avatar
Originally Posted by steve1986 View Post
anyone had any problems using the hobbywing esc with spektrum radio system? I have the xerun 80a 1/8 esc it seem like the drawing the current from the receiver when under a load the receiver looses power I am using the dx3 with sr3000 receiver.
You are getting a voltage drop. Fit a cap to the reciever and it will be sorted.
Had the same issues with my EZrun 80amp in my Fusion buggy. I used a 470mfd16v cap fitted onto a servo plug and plugged into the battery channel on the reciever. Alternative is using a ubec or lipo regulater.
razzor is offline
Old 06-03-2010, 11:12 PM
  #874
razzor's Avatar
If using a ubec or regulater just remove the red lead from the esc lead.
suggest remove it from the plug and insulate it so you can use it again if needed. Note you need the red connected if you do esc programming of settings or firmware updates.
razzor is offline
Old 06-04-2010, 12:16 AM
  #875
ozzy-crawl's Avatar
thanks for that will give the cap a try
Old 06-04-2010, 01:43 AM
  #876
I have a Xerun & 3 Ezruns that I run with SR3000's
The problem you may be having is the servo drawing too much power or spiking/putting hash into the RX.
Its a Known issue, Spektrum sell a cap that connects to the RX as a fix.
I have 4 different servos I cant use with sr3000's.
1101 is offline
Old 06-04-2010, 05:09 AM
  #877
Trader Rating: 8 (90%+)
Originally Posted by bigdanes View Post
ok several of us have asked the question about running xerun with 1s with a receiver pack. mine just came in today and hooked it up and the motor seemed to run great my only issue is I cant get the esc to calibrate to my radio. Any help would be grateful.
the radio is KOPROPO (jrz1) with spektrum
bigdanes is offline
Old 06-04-2010, 11:08 AM
  #878
thanks 4 the help! tried it this morning works great
Attached Thumbnails XERUN V2.0 Brushless ESC discussion thread.-100_0568.jpg
Old 06-05-2010, 12:28 AM
  #879
Humyu's Avatar
Hi
New to Xerun 120Amp. soo newbee question. What is the best setting for Mid track not so technical. Using 11.5t motor.FDR and Esc setting. Sorry if question have been asked before.
Humyu is offline
Old 06-05-2010, 01:16 AM
  #880
Default set up for 13.5 in a low grip track
I am just wondering how to slightly soften the speedo as the car comes out of corners - I have just found it a bit too aggressive for me.
I use the 518 software.
Out of interest can the 1st gen Speed Passion LED controller be used to properly set up the Hobbywing 120A or do I require an LCD controller
Lohan is offline
Old 06-05-2010, 01:20 AM
  #881
Registered User
Trader Rating: 8 (83%+)
use less trigger out of the corner
shano83 is offline
Old 06-05-2010, 01:46 AM
  #882
thanks for that facetious response, you should be given a medal for your superb sarcasm and wit perhaps an oscar for your brilliant forum response
something more constructive might be of use
Lohan is offline
Old 06-05-2010, 01:50 AM
  #883
I agree lol!
If you're running an 13.5, i'd lower the timing punch (15) to setting 4,5,6. (which is -3, -4, -5.) This makes the biggest difference of all, as it makes the timing ramp longer, so the car is more progressive in acceleration, rather than a surge. Also, I run timing start at setting 1 (3,000rpm) as it makes the ramp longer still and there is no lump when the timing comes in.
maxg123456 is offline
Old 06-05-2010, 03:50 AM
  #884
Default thanks
cheers mate - I'll give it a go - my last speedo was a nosram stock spec - and the oomph is just not on the same level as this speedo
Lohan is offline
Old 06-05-2010, 04:00 AM
  #885
you could also drop DRRS (4) to 7 or lower. 7 feels a lot flatter than 8 / 9
geubes is offline
