Old 05-05-2010, 05:12 AM   #706
Trader Rating: 22 (100%+)
Originally Posted by BILKO1 View Post
Well after trying several more pc's / laptops i think the Hobbywing lcd programmer is not compatible with Intel processors. I've found 3 pc's / laptops that the programmer works on and all are using an AMD processor. Not happy as i only have Intel based computers
Did you run as administrator?
Only way i could get it to work on vista (intel processor).
bjspinner is offline   Reply With Quote
Old 05-05-2010, 05:19 AM   #707
notatoy's Avatar
the programmer runs no problem at all on AMD proccessers i have used intel and AMD not a problem . you must be doing something wrong
notatoy is offline   Reply With Quote
Old 05-05-2010, 05:24 AM   #708
defcone's Avatar
Trader Rating: 15 (100%+)
Running a Centrino 2 setup on windows 7 64bit with no problems with the Hobby Wing Software.
defcone is offline   Reply With Quote
Old 05-05-2010, 05:28 AM   #709
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
This may have been asked...
But can the XERun ESC run on a single cell lipo, If not are there plans for it in the future?
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 05-05-2010, 05:34 AM   #710
notatoy's Avatar
at the moment know it is under development
Old 05-05-2010, 07:10 AM   #711
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
Hey guys is SC RPM the same as start or end RPM???
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 05-05-2010, 07:47 AM   #712
Send a message via MSN to hobbywing Send a message via Skype™ to hobbywing
Yes, the 1s Lipo ESC is just being developed now.
hobbywing is offline   Reply With Quote
Old 05-05-2010, 07:59 AM   #713
sg1
sg1's Avatar
Thanks for the info.
I sent a PM to you.
Thanks!
Old 05-05-2010, 08:36 AM   #714
racerb's Avatar
make it optional with a booster would be sweet
racerb is offline   Reply With Quote
Old 05-05-2010, 08:47 AM   #715
Yep tried Adminstrator, only works on AMD my end also works on Windows 2000, XP and Vista as long as is AMD.
BILKO1 is offline   Reply With Quote
Old 05-05-2010, 10:57 AM   #716
Send a message via MSN to geubes
sure its not a usb problem with the intel motherboards you have? how old are the chipsets. is usb 2.0 supported on them? and do you have power through USB enabled if its old?
for record, my pc and netbook are both intel chipset motherboards
geubes is offline   Reply With Quote
Old 05-05-2010, 01:57 PM   #717
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
just curious as to where you can buy these ?
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 05-05-2010, 02:07 PM   #718
notatoy's Avatar
the card or the system ???
Old 05-05-2010, 03:21 PM   #719
mc4798's Avatar
Would you guys recommend the 60amp for 21.5 vta racing and 17.5 corr truck ? I will be replacing a couple burnt up novaks gtb's.
Using a 21.5 novak ss motor and 17.5 ballastic motor.
Will the turbo function work with those motors also ?
mc4798 is offline   Reply With Quote
Old 05-05-2010, 03:26 PM   #720
Hey guys is SC RPM the same as start or end RPM??? For SC RPM Delay, SC Full throttle delay etc...
