XERUN V2.0 Brushless ESC discussion thread. >
Old 05-03-2010, 06:17 PM
  #691
Originally Posted by itsjay764 View Post
Can you run the Hobbywing XERUN v2.0 60/120A with 1s lipo without a booster?! ...
Jay
The XERUN 60A/120A V2.0 can only work with 2s and 3s lipo. There isn't a DC-DC booster in the ESC, so it cannot work with 1s Lipo.
But we are just developing an ESC supports 1s Lipo.
hobbywing is offline
Old 05-03-2010, 06:20 PM
  #692
are you sayimg it wouldnt even work with a 1s booster?!
itsjay764 is offline
Old 05-03-2010, 06:55 PM
  #693
Yes, we don't recommend using 1s lipo for XERUN-120A/60A even if you are using an external DC-DC booster.
If an ESC works reliablely with 1s lipo, the lowest working voltage should be less than 2.7V, but XERUN-120A/60A ESC can only works with a minimum voltage of 3.0-3.2V (Ignoring the function of built-in BEC)
Hobbywing will release its 1s ESC ASAP. The R&D department is working hard at it and everything seems OK by now. so we are confident about this new product.
Old 05-03-2010, 07:35 PM
  #694
unsp0ken's Avatar
Trader Rating: 25 (100%+)
Any plans for new firmware updates for the 150A? It would be awesome to see a current limiter feature.
unsp0ken is offline
Old 05-04-2010, 06:31 AM
  #695
notatoy's Avatar
Can you run the Hobbywing XERUN v2.0 60/120A with 1s lipo without a booster?! Can anyone confirm this? I am gonna be using it on 12th scale with a digital JR z3590 that is a power hog. Deciding wether to go spec esc/motor class that my local track has or just get the xerun with a duo/duo 2 17.5 and have a blast trying to play with all the cool turbo/superchrge/timing options it has....what do you think?! I am new to RC. Thanks in Advance
Jay
as far as i know this is under development the 1s lipo you would be best to run a seperate bec for such a big servo i would say defo go for the xerun but only if you whant to win races edit as above .lol..
notatoy is offline
Old 05-04-2010, 08:28 AM
  #696
The turbo timing technology is generally applied for EP on-road touring car ESC, we need to do some tests for big ESCs such as XERUN-150A, they are normally used for 1:8 scale buggy and truggy, I really don't know what will happen when the turbo timing is activated in such a big car.
But it will be interesting to do the tests
Old 05-04-2010, 08:34 AM
  #697
Jochim_18's Avatar
One this for sure it will help you clear those big jumps....
Jochim_18 is offline
Old 05-04-2010, 10:47 AM
  #698
unsp0ken's Avatar
Actually, I really don't think turbo timing is needed on the 1/8 offroad cars, especially since the trend nowadays is to dial down power to make things controllable. We're already overpowered as it is. A nice feature I'd like to recommend is a current limiter feature similar to that found in the Tekin RX8. It'll help maintain traction by limiting the amount of current (and therefore, torque) supplied during acceleration to make things more driveable. Right now, my DDRS start setting is at Level I, zero timing and still feel I have way more punch than I need.
But anyway I know this is an onroad thread but I like to post questions here since this is the most active Hobbywing thread. Sorry onroad guys .
unsp0ken is offline
Old 05-04-2010, 11:02 AM
  #699
Jochim_18's Avatar
A Good setup that we fund and efficient on 1/8th Off-road is a Big motor like 2600KV and 3S lipo... It's fast enough and controlable but with turbo it will help it more to clear jumps with ease...
I tried 4S Lipo way too much power it's insane.... With track that my friend design clearing 45ft triple I say you will need a turbo..
Old 05-04-2010, 11:22 AM
  #700
unsp0ken's Avatar
What motor were you running with the 4S battery? I personally wouldn't run any motor rated for more than 2100KV on 4S. The Tekin 1900KV or Neu 1850KV are probably the best options for power, smoothness and efficiency.
The problem with HIgh KV and Low Voltage setups is that they are inefficient and typically run hot during summer months. I personally went the other route: Low KV (1400KV) motor on 6S. 5S would work too, just add timing advance if you need more top end. My setup runs cool and efficient at 140-200mah/min @ average temps of 110F (pretty good for a big car huh). Low KV motors are also smoother than higher KV setups. The turbo feature is not a bad idea for 1/8 offroad for those who feel that they need it, but my guess is most people won't use it.
unsp0ken is offline
Old 05-04-2010, 11:28 AM
  #701
Question for those of you in the US... where did you get your Xerun 60a/120a from? If e bay, which seller?
Thanks!
g26er is offline
Old 05-04-2010, 11:31 AM
  #702
unsp0ken's Avatar
Thanks!
I got my 60A from ebay. You can also get them from rcfans-88.com or himodel.com. They're all in China. If you get EMS shipping from rcfans-88 or himodel, you should get them in a bout a week or so. Not too bad.
unsp0ken is offline
Old 05-04-2010, 11:51 AM
  #703
Thank you!
g26er is offline
Old 05-04-2010, 12:43 PM
  #704
Jochim_18's Avatar
I use to run Castle MMM with 2650KV motor and TP 5000 3S on D8 works awesome... Motor temp and battery temp is around 150-160 degrees... I did an extensive testing since I own a Off-road track and for the track size that we have 200x140 this battery and motor combo it's not problem and it's very efficient when we did the testing. And it's a lot faster than 4S lipo since your car is a lot lighter....
Old 05-05-2010, 03:44 AM
  #705
Well after trying several more pc's / laptops i think the Hobbywing lcd programmer is not compatible with Intel processors. I've found 3 pc's / laptops that the programmer works on and all are using an AMD processor. Not happy as i only have Intel based computers
BILKO1 is offline
