Old 04-15-2010, 01:50 AM   #571
AGNO's Avatar
Originally Posted by Darrin70 View Post
Looks like it is your Motor rotation 1= Counter Clockwise 2=Clockwise
I thought the same thing but does not appear active, but not so useful.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 04-15-2010, 01:54 AM   #572
AGNO's Avatar
Default SW324
I tried the SW 324 with good results, all functions now respond well to adjustments mainly # 15 which helps to get a good push.
Old 04-15-2010, 05:10 AM   #573
Thats great.
Could you share your settings for the esc pls? Also what motor, car, and FDR.
thanks in advance.
sammies is offline   Reply With Quote
Old 04-15-2010, 06:01 AM   #574
Akudou's Avatar
410 works great for me. was going against the 231 and can see the difference in torque and power at 7.9fdr. Problem is i still need to improve on my brake choices as it tends to overshoot. Local track of mine has 25 to 30m straight and lots of tight 180 corners.
Akudou is offline   Reply With Quote
Old 04-15-2010, 06:04 AM   #575
cherry2blost's Avatar
Can you post your settings for us so we know what is required.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 04-15-2010, 06:29 AM   #576
adri-13's Avatar
for C2B=> the 410 soft is more fast than the supercharger soft? what's the differences?
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 04-15-2010, 06:40 AM   #577
Akudou's Avatar
1, 1
2, 3
3, 4
4, 8
5, 3 - remote 80%
6, 1
7, 2
8, 1
9, 5
10, 1
11,
12, 6
13, 3
14, 1
15, 4
416X
fdr 7.9
motor- Team power 11.5T
Battery- Intellect 5000mah 45C
track asphlat
tyre- sorex 40R
motor temp- +67deg c after 10min on a 28deg c track. Even the 231 my friend was using have the same temp but on 5 min run.
Can try gear up to above fdr 8 to gain more torque but need to concentrate on the brakes as it keeps overshooting on my racing line.
Tomorrow am trying my SXX stock spec mk3 to check the difference while my tekin rs pro is awaiting the new firmware 204
Check your pm too bro
Old 04-15-2010, 06:51 AM   #578
Thanks Felix have also replied to your PM sorry didn't see it as had some hassle from moderator again.
Old 04-15-2010, 07:02 AM   #579
Akudou's Avatar
Understandable. I did experience a lil glitvh i think. i crashes hard into a barrier and steering was working, esc was blinking green light which is always overheating problem but usually when its overheated, the motor wouldnt move despite triggering the throttle but in my case, the motor was still moving when i trigger my throttle and temp on the esc was only 45+ deg c. So to be safe i switch it off and let it rest for 5 minutes and blasted away again this time without any problem except that i broke my solid plastic outdrives this time due to a crash .
Anyway just pm me your previous settings on the 2 firmware that you tried as i am quite bz to turn back the pages. Thanks CB!!!
Old 04-15-2010, 07:06 AM   #580
AGNO's Avatar
error
Old 04-15-2010, 07:21 AM   #581
Akudou's Avatar
error
error?
Old 04-15-2010, 02:05 PM   #582
AGNO's Avatar
error?
I made a mistake in the answer and I can not delete the post ...
However, this is the setup I used:
This track is very small and technical and you can see here:
http://www.automodellistivaldarnesi.it/
Old 04-16-2010, 12:56 AM   #583
razzor's Avatar
would suggest anyone using the supercharger software and more so those using Spektrum to put a capacitor on the reciever.
With fast acceleration out of corners there have been instances of loss of control and it seems to be getting more common.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-16-2010, 02:37 AM   #584
steliosh's Avatar
It has happened a few times with my futaba PCM 40Mhz, using the XE120A erun with mod motors (std software), both in buggy (6.5T) and TC (5.5T)...
I am going to revert to 2.4Ghz, though, one of these days, with a Corona module/receiver. Have been running this Corona combo (same transmitter) on my 1/5 KP09 bike, along with 13.5T and XE60A (std software, so far) with the same batteries and no glitches at all...
Can you be more specific on what type of resistor and how to connect it?
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 04-16-2010, 07:02 AM   #585
xrayal's Avatar
318,324 and 410 for some strange reason seem dog slow compared to 231. I'm running sp gt2.0 pro with an ultrasportsman 13.5........
A friend of mine is running gt 2.1 with gm10.5 and 410sw and its a fu..ing mad speeds!
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
xrayal is offline   Reply With Quote
