XERUN V2.0 Brushless ESC discussion thread. >
Old 04-12-2010, 03:15 PM
  #541
Redwood's Avatar
Originally Posted by Redwood View Post
Hi guys, I wonder if anyone can help.
My friend got a XERUN 120A v2.0 speedo and ran it for the first time yesterday with the supercharger software.
It has a strange problem though, if you switch it on and race immediately then it is lightning fast, perfect. However if you switch it on and leave it idle for a short time (like the start of a race) then there is no punch or top speed any more, and is generally very slow. If you turn it off and on again the punch and speed are back.
Any suggestions? I honestly can't think whats up.
Regards
Neal
Just an update;
My friend ran tonight with a different motor, 17.5 instead of the 10.5 he experienced problems with. the problem was gone, so if you suffer from the same problem it seems to be motor related.
It seems to be a sensor issue, either the rotor is not shimmed close enough to the sensor board or the sensor board is dodgy.
Hope this can help someone.
Regards
Neal
Redwood is offline
Old 04-13-2010, 04:24 AM
  #542
Born2Run's Avatar
Hobbywing hellooooo.Is anybody listening? Still waiting for your stock software.Is there any possibility withing 2010?
Born2Run is offline
Old 04-13-2010, 08:01 AM
  #543
Originally Posted by dameetz View Post
Ok, here's the complete set up of my friend's XeRun 120 with 231 firmware.
1-1
2-2
3-5
4-7
5-3
6-1
7-2
8-2
9-6
10-1
11-1
12-7
13-4
14-4
15-4
Car is TRF 416X, FDR 8.23 (I thought it was 7.99 as per my last post), motor SP 11.5T with stock timing on motor (mid position which I think is 5 deg), temp of motor after 5-6mins run is around 67-70C ish. On straight, on par with my Tekin with 203 firmware and same motor but still my Tekin has a bit more rip out of corner.
cool thanks, for mine, i am running FDR 7.3
12-7
13-4
14-7
15-3
hoppie is offline
Old 04-13-2010, 08:08 AM
  #544
Originally Posted by Born2Run View Post
Speedo turns in sensorless mode.I don't know why that happens and how to cure this.And you aren't the only one who has this issue.
i had this problem too, the problem occurs when i push my FDR down to 6.6 from 7.0 which was running fine for a 11.5T motor.
What i did later is to swap the Sensor board on the motor and it's working fine again, seems that gearing too aggressively will kill the sensor board.
hoppie is offline
Old 04-13-2010, 08:50 AM
  #545
Born2Run's Avatar
Well,i don't know whats going on with HW and i realy don't care anymore as i have already moved to the Mamba Max Pro with great results and without wasting my time with HW and SP issues.
Born2Run is offline
Old 04-13-2010, 09:48 AM
  #546
Redwood's Avatar
Thanks for the input, perhaps some excess heat damages something. I will try to shim the rotor closer to the sensor board. If that doesn't work it looks like a new sensor board is needed.
Neal
Redwood is offline
Old 04-13-2010, 10:28 AM
  #547
Born2Run's Avatar
Neal
It's not the motor.I had this problem with two motors.With the same motors and sensor cables but with a Mamba Max pro everything is perfect.If it was a motor, sensor board or sensor cable,i sould have the same problem with the other speedo.
Born2Run is offline
Old 04-13-2010, 10:34 AM
  #548
Born2Run's Avatar
Neal
Neal before to shim the rotor closer to the sensor board,try decrease the motor endbell timing.Maybe it works.
Born2Run is offline
Old 04-13-2010, 12:42 PM
  #549
Redwood's Avatar
Thanks, I appreciate your help but its a V2 motor, no adjustable endbell timing..
What were the symptoms of your problem?
Regards
Neal
Redwood is offline
Old 04-13-2010, 01:30 PM
  #550
Born2Run's Avatar
Regards
Neal
I don't think V2 is no adjustable endbell timing but im not sure.Could you post some photo?
Born2Run is offline
Old 04-13-2010, 01:54 PM
  #551
Redwood's Avatar
This is the motor:
I realise it doesn't show the back but I cant take a photo of the motor right now.
The V3 I have has a cut-out in the rear around the sensor port so that it can be moved forward and back. The pictures motor doesn't, so I assume you are not meant to change the timing, but maybe there is a way to do it?
Regards
Neal
Redwood is offline
Old 04-13-2010, 02:23 PM
  #552
Trader Rating: 22 (100%+)
This is the motor:
Regards
Neal
The version 2 speedpassion motors where the worst for cogging problems when they got warm and benefited greatly from shimming of the rotor.
No timming to adjust though.
bjspinner is offline
Old 04-13-2010, 08:30 PM
  #553
Born2Run's Avatar
This is the motor:
Regards
Neal
Neal this is not a V2 series.It's an ultrasportsman and is not time adjustable.Anyway i don't think that the problem when speedo goes to sensorless mode has nothing to do with the sensor board or sensor cable or FDR.Maybe because of some excess motor timing or some software issue.It's very possible that shimming the rotor closer to the sensor board helps a lot (i haven't try it) so give a try.
Born2Run is offline
Old 04-13-2010, 08:55 PM
  #554
kschu's Avatar
Trader Rating: 16 (100%+)
SP latest 410 software
kschu is offline
Old 04-13-2010, 09:34 PM
  #555
dameetz's Avatar
Originally Posted by kschu View Post
Is it for stock? Have you tried it bro?
dameetz is offline
Copyright İ 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
