Old 04-09-2010, 12:30 AM   #511
Born2Run's Avatar
V1.10_090205g_T and V1.10_090323a_T for mod
Whatever
Born2Run is offline   Reply With Quote
Old 04-10-2010, 11:17 AM   #512
xrayal's Avatar
Default hrcc friday night settings
cherry, i dont know how to post the set up sheets so ill do it manually....
1-1
2-1
3-4
4-9
5-4
6-1
7-2
8-1
9-5
10-1
11-/
12-9
13-1
14-1
15-9
small indoor technical circuit, high grip carpet,sweep 32s/sorex 28s
temp-40
supercharger cut in at around 3/4s of the straight. couldnt get it to come in sooner.
fdr 8.2, finished on 7.8 (2 pinions higher)
top speed equal to tekin but couldnt reach it as fast as they did.
seemed a bit soft.
going to 231 for next friday.
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
xrayal is offline   Reply With Quote
Old 04-10-2010, 11:35 AM   #513
adri-13's Avatar
what's the temp motor after a run with your set-up??
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 04-10-2010, 03:28 PM   #514
xrayal's Avatar
40 degrees, should be running at around 65degrees. might go up a couple of pinions............
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
Old 04-11-2010, 03:41 AM   #515
hey guys, what would be esc xerun 60a upload for 13.5t truck? sorry but i can't tell which esc thing to choose, I have the lcd program card, just don't know which version to choose. thanks
reconrc is offline   Reply With Quote
Old 04-11-2010, 06:21 AM   #516
AGNO's Avatar
1-1
2-1
3-4
4-9
5-4
6-1
7-2
8-1
9-5
10-1
11-/
12-9
13-1
14-1
15-9
temp-40
seemed a bit soft.
How can you have set the # 15 to value 9? I have only 6 values.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 04-11-2010, 06:29 AM   #517
Originally Posted by gazmond View Post
If anyone is struggling to get their 1.04 LCD box to downgrade to 1.02 so they can use the speed passion software here is what I did to get mine working:
1) - Make sure you have both the 1.6 and 1.5 HW software installed on your machine.
2) - locate the version_control file in your 1.6 folder and copy it.
3) - Now browse to your 1.5 install folder, locate the version_control and rename it to version_control_old.
4) - Paste in the version_control file from the 1.6 install folder into the 1.5 install folder.
5) - Run the 1.5 HW software and downgrade your lcd box to 1.02, you can then put the speed passion software onto this lcd box.
This is basically a re-worked version of X Men's (thanks for the idea dude!) way of doing it however his way didn't work for me but then I thought I'd try swapping files and it did. My box is a black buttoned one that came with 1.6 on a CD had the version number 091229 listed on the instruction manual that comes with the box.
There is a easier version:
My Lcd came with HW1.6 usb link, but I can't find HW 1.5 software and my included cd comes with 1.6 too so, this it's what I did.
1: Install SP 1.32 (downloaded from speedpasion web)
2: Install HW 1.6
3: Find version _control.ini on HW installation and copy it
4: Rename version_control.ini on speed passion installation to "old" or something
5: Paste HW version control.ini on speed passion installation
6: Run speed passion usb link and downgrade directly
prorace is offline   Reply With Quote
Old 04-11-2010, 08:59 AM   #518
Anyone has FDR for a 11.5R motor when running the supercharger softeware? I had a race today and only got the firmware last night, tried to follow FDR for Tekin at 7.83 but seems slow in high speed then gradually drop to 7.3 but finally decide to go aggressive to go 6.66 and i blew my Sensor board on the motor, changed a sensor board and up the FDR back to 7.3, was running fine on 1 qualifying but still slow, so decided to up the punch on DRRS and Supercharger to 9 and also advance the timing to 26.25.
The nightmare happened, ran about 10laps and motor smoked out blew a motor today.
Got another Speed passion 11.5R V3 motor and decided to tune down abit with FDR of 7.2. brought the DRRS to 8, ATMS 15, punch 7, etc. Ran quite well able to keep up with the tekin RS guys, long straight side by side but will still lost out the the final approached but everyone got to brake so i guess it's fine.
hoppie is offline   Reply With Quote
Old 04-11-2010, 09:34 AM   #519
dameetz's Avatar
My friend is using 7.99 FDR with SP 11.5 V3 motor, temp is aroumd 67-70C ish. On par with my Tekin on the straight, only the my Tekin has a bit more rips out of corner. This was with 231 firmware.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 04-11-2010, 05:38 PM   #520
Care to share your supercharger setting ? (parameter 12-15)
TIA
leonardiw is offline   Reply With Quote
Old 04-11-2010, 06:41 PM   #521
Can share your friend's DRRS, ATMS and 12-15 parameters? meanwhile i am digging my out when i get home after work.
Old 04-11-2010, 06:52 PM   #522
Trader Rating: 22 (100%+)
1-1
2-1
3-4
4-9
5-4
6-1
7-2
8-1
9-5
10-1
11-/
12-9
13-1
14-1
15-9
temp-40
seemed a bit soft.
324?
Try setting 15 at a lower setting
Try setting 9 higher
bjspinner is offline   Reply With Quote
Old 04-11-2010, 10:45 PM   #523
dameetz's Avatar
I ll post it later if I meet my friend at the track.
Old 04-12-2010, 01:51 AM   #524
cherry2blost's Avatar
1-1
2-1
3-4
4-9
5-4
6-1
7-2
8-1
9-5
10-1
11-/
12-9
13-1
14-1
15-9
temp-40
seemed a bit soft.
Assuming that's 324 Al, have you tried 318 yet, as 324 may just be an incremental adjustment I have found that my car is very quick on the infield at Maritime (not as quick as the MMP mind) and is almost as quick as every one else on the straight. I have problems with my driving ability which seems to negate the benefits of going any quicker lol. Somehow set up aggresively 231 seems to 'feel' better to drive.
Anyone tried 318 with any success may try an evening of 318 this Thursday, you fancy the trip Al?
With the setup sheets screendump em into Paint, save as and then post them as JPEGS (photobucket works for me)
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 04-12-2010, 03:47 AM   #525
xrayal's Avatar
that was 324. i havnt tried 318 yet.thanks for the invite, its a bit far for a thursday night lol. im on call out next weekend, but maybe possible the sat after if maritimes open, otherwise its hrcc in ware on a friday night......
the boys runnind 10.5 seems to love 324. they had v.good top end and v.reasonable infield................... i went from 8.2 to 7.6 think ill go to 6.5 and keep an eye on the temps.if you fancy friday ill book you in for free!
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
