Old 03-15-2010, 11:39 PM   #391
unsp0ken's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Akudou View Post
Thats good news. Any link to it?
http://www.hobbywing.com/english/downloadsm.asp?id=31
Hmm.. I don't see any new firmwares for my ESC's though. Still can't update my Turnigy LCD box, but it does say database version 1.71. Post if you guys see any differences.
unsp0ken is offline   Reply With Quote
Old 03-16-2010, 12:22 AM   #392
Born2Run's Avatar
Too late for me The new update from SP with the supercharger is the way to go and after all i still have my Mamba Max Pro to run.I don't even give a try to this new firmware.
Whatever
Born2Run is offline   Reply With Quote
Old 03-16-2010, 01:46 AM   #393
Akudou's Avatar
only database update. Firmware still same and also firmware doesnt have sp latest ones.
Akudou is offline   Reply With Quote
Old 03-16-2010, 06:02 AM   #394
My problem now is i cant reset the esc to recalibrate with my remote whether its the new sp beta firmware, the old one or the HW firmware. Anyway of solving this?
Hi
I'm having a simular issue.I got a 3pk, and just got off the phone with a mate of mine and he suggested to try to calibrate the speedo with my radio at 90%.Then turn it up to 120%. He had the same situation as me with his Tekin. Calibrated OK ,then went out of calibration several laps latter and lost turbo.
To late here to try it but will after coffee in the morning.
TBOTubed is offline   Reply With Quote
Old 03-16-2010, 06:14 AM   #395
BTW- Thanks for the effort Cherry!
This should all keep us pretty busy!
Old 03-16-2010, 11:26 AM   #396
cherry2blost's Avatar
Aww thanks mate it's nice to be appreciated
BTW am gonna relink here again...
Supercharger: http://www.rctech.net/forum/7130543-post362.html
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-17-2010, 07:29 AM   #397
Hi all,
My Turnigy 2 in 1 Professional Program Box turned up today....
Unboxed
Plugged into 120SD Speedo with ‘new’ Speed Passion Supercharger software on it.
Does not seem to want to update the firmware on the program box all are coming up blank but it allows the programming of the ESC anyway. Here it is attached to ESC and PC note the SP 1.32 (Modified) Software on PC
Close up shots of the Speed Passion Software and showing the ability to flash with the New Profiles.
Hope this helps, as I have said before you use these boxes AT YOU OWN RISK they are not ‘meant’ for our Speedos, so there you have it.
Cherry xx
Old 03-17-2010, 08:44 AM   #398
unsp0ken's Avatar
That's exactly how my Turnigy box is lol.
Old 03-17-2010, 08:58 AM   #399
Originally Posted by cherry2blost View Post
Hi all,
Hope this helps, as I have said before you use these boxes AT YOU OWN RISK they are not ‘meant’ for our Speedos, so there you have it.[/COLOR][/SIZE]
Cherry xx
Hi, Cherry.
Have you run or tested this software on your track.
Please show the results.
Keep going
Ed
eded1 is offline   Reply With Quote
Old 03-17-2010, 09:05 AM   #400
Originally Posted by eded1 View Post
Hi, Cherry.
Keep going
Ed
Tomorrow is the big day, have just dropped my best motor OUT of the car and put in a spare Novak 10.5 with a 13mm Rotor, as didn't want to blow my Fantom motor. Revving it up on the bench it sounds like a dentists drill and the turbo kicks in really well and you can hear when you adjust the revs at which it comes in, have mine set to 10k RPM but may need to drop that on the track, all other settings are at minimum except AMTS which is at the stock 11.25. Will update on the condition of my motor on Friday, kinda expecting it to blow though.
Old 03-17-2010, 09:08 AM   #401
Bit lost....
Does this mean the Turnigy box works with the SP software?
You say you can't update the firmware on the LCD box but that it works to put the new SP software onto the speedo?
gazmond is offline   Reply With Quote
Old 03-17-2010, 09:09 AM   #402
Originally Posted by gazmond View Post
Bit lost....
Well I just used it to reflash my ESC and it 'seems' to be working................
Old 03-17-2010, 09:11 AM   #403
Good enough for me!!!
Thanks again Cherry.
Old 03-17-2010, 09:13 AM   #404
Welcome
Old 03-17-2010, 09:24 AM   #405
dameetz's Avatar
My mate has tested this 231 firmware on his XeRun120 side by side with my Tekin RS Pro firmware 203.Both of us are using SP11.5T motor, FDR 7.99, same car TRF416X and same tyres. On a very long straight I say the top speed is almost the same as my Tekin. How ever my Tekin has more rips out of corner. When I drive his car I felt it was a bit soft in punch and the supercharger would only come in about 2/3 of the straight distance. Our motor temp was about the same at around 67-70ish deg C. this was only for initial test, I m sure this can be improve with a bit of fine tuning the esc set up. Overall I m impress with the new firmware. I just wish that the HW guys gave this firmware during recent TITC that I attended, at that time they only gave us firmware 229 eventhough we saw this 230 and 231 firmware on his PC.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
