Old 03-04-2010, 11:56 PM   #271
cherry2blost's Avatar
Originally Posted by irgo View Post
waiting for your re-flash
Hi Irgo you are going to have to wait till after the weekend now as am not going home until Sunday now and have left the disk at my home, sorry dude will UPLOAD it as soon as I can.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-05-2010, 12:01 AM   #272
irgo's Avatar
OK.
since i got HW SOFT version 1.6 and 1.5 , that can't do re-flash ESC
So you're saying that your older software can re-flash ESC Firmware Damaged ?
Quark Force
irgo is offline   Reply With Quote
Old 03-05-2010, 03:57 AM   #273
Born2Run's Avatar
irgo i have the V1.5_090424 if it helps you.
Whatever
Born2Run is offline   Reply With Quote
Old 03-05-2010, 04:23 AM   #274
irgo's Avatar
ok, where can i download V1.5_090424 ?
No, the V1.5_090424 also canot re-Flash.
the About Tab only viewed.
Quark Force
Old 03-05-2010, 04:33 AM   #275
Born2Run's Avatar
irgo you have a PM
Whatever
Old 03-05-2010, 04:34 AM   #276
OK.
Irgo I am saying that it has worked for us in the past, not always mind you but it has worked before. Try it before you send back to Hong Kong. If it works great, if not then you haven't lost anything
Old 03-05-2010, 04:44 AM   #277
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Hi All,
I recently purchased a 35a speedcontroller and was wondering if anyone has any info on if there will be any updates to the max. timing. I currently have it at max, I believe 26.5 degrees, but run a class with fixed gearing and motors. A bit more timing would help, anyone know about higher timing.....
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 03-05-2010, 04:55 AM   #278
yobouno's Avatar
Originally Posted by sg1 View Post
Hi All,
Sound like you're running m-chassis racing. if you have the ESC card, that the best you can do. Any "re-jigging" of your ESC's software may disqualify your car from the class.
TAMYA M05, TB03, TA05 V2, TRF417X
yobouno is offline   Reply With Quote
Old 03-05-2010, 04:58 AM   #279
irgo's Avatar
yes i am doing your suggestion.
and the result is :
Hobbywing_USB_Link_setup_V1.6_091229 -lcd upgrade only but esc upgrade is unavailable
Hobbywing_USB_Link_setup_V1.5_090820 -lcd upgrade only but esc upgrade is unavailable
Hobbywing_USB_Link_setup_V1.5_090424 -lcd upgrade only but esc upgrade is unavailable
still cant see the esc Upgrade Button, and only LCD Upgrade button available
try the LCD Upgrade v1.02, and restart esc,
and i'm looking at the software still not showing any Esc Upgrade Button.
So Re-Flash can't be done ?
perhap's older version might work if anyone have, or any other suggestion ?
Quark Force
Old 03-05-2010, 04:59 AM   #280
Hi All,
Hi friend, you really need to be looking at the EZRUN thread, as that is where most of the information for the 35amp will be.
http://www.rctech.net/forum/electric...system-55.html
Old 03-05-2010, 05:02 AM   #281
and the result is :
Sorry Irgo, seems you are being unlucky here, will check to see what the oldest ver on the software is and will let you know Monday.
Old 03-05-2010, 05:08 AM   #282
irgo's Avatar
Thank you Cherry2blost and Born2Run,
many suggestion and i will try it.
and Razzor, i'm still waiting your software ?
Quark Force
Old 03-05-2010, 07:44 AM   #283
razzor's Avatar
irgo you have the same software versions i have.
seems the hassle you having is possibly due to the esc not powering the lcd.
Check that there is voltage on the red wire that plugs into the lcd programmer.
I have a Xerun that gave me that hassle.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-05-2010, 09:05 AM   #284
irgo's Avatar
Oh, razor i know that.....
Sure everything is alright including the voltage on ESC, is Fully Charged 2S.
as the LCD is turned on after i switch the ESC on, before connecting usb.
You all here might miss some information about Firmware Damaged.
The Esc is alright, as the power is on, and The fan will spin normally fast, if the esc is switch on.
LCD firmware also alright, as i always telling the LCD Firmware can be Upgraded Through all software i tested, including HW and SP USB Link.
The problem is, When The ESC is on while everything is connected,
The software did not detect ESC, same as if LCD to ESC only, it will not read any settings from Esc.
The ESC it self is Green light continuously on (where is abnormal), since the Firmware Damaged.
The case is :
Firmware Damaged is happen when upgrading/updating the ESC Firmware to the ESC, and accidentally Disconnected the Power when the process is not 100% completed it's like just 25% or so.
and if ESC is rebooted or switched back off and on, The ESC is on but failed on booting.
That's why we call it Firmware Damaged, if you followed the Firmware Damaged Case Thread.
and untill now, the Way to Re-Flash is still looking for.
I thought you are that RAZZOR that do something with Software,...
as you do at IT world...
SO... The only way to do Re-Flash is by making the software able to Flash the ESC Firmware without detecting boot on ESC, like TeamWave Does,,,
TeamWave can do such thing as i called them The Best Method Updating/Upgrading/Flash Firmware.
Please Follow This link to Understand the case first
http://www.rctech.net/forum/electric...-solution.html
Quark Force
Old 03-06-2010, 04:07 AM   #285
Hi All,
Hi SG1
We also run a fixed gearing, speedo and motor class(HW EZRUN 60amp,HW 17.5, any brand lipo up to 5000mha, 4.2FDR). When first did testing, comparing 4 different cars,Tamiyas, Losi, XRAY, all with different internal ratios, all different wieghts, they showed no noticable difference in top end speed down the straight. The big difference was seen after several laps due to car set-up, free drivetrains and driver ability(dam that last one!) So if your getting left behind I might suggest set the punch control to the setting that makes the car comfortable to drive, insure that your car is as free as it can be or free-er, try different set-ups and practice,practice,practice
TBOTubed is offline   Reply With Quote
